D30 problems/questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 15th, 2011, 07:29 PM   #1
Daniel
SFA Ranger
Daniel's Avatar
Angry D30 problems/questions
I had my balljoints replaced over the winter (by someone on here) and the grease fitting got broke off the axle joint, thus causing the problem I think.
The axle joint isn't even that old, I replaced it last spring I believe.
Anyways, the axle joint is causing the axle shaft to move around in the housing. I noticed the pinion seal leaking about the same time I started hearing the clicking noise.
I really don't want to pull the whole carrier to replace the seal, I don't have the tools or a place to do it.
Could it be leaking because of the way the axle shaft is moving, or is the seal shot. The seal was replaced a few years ago when I bought the axle.
I checked everything and it feels normal and I hear no bearing noise(except the axle joint).
Heres a video.
http://youtu.be/I4nTIHUFF3k
Daniel is offline   Reply With Quote
Old April 15th, 2011, 07:33 PM   #2
steveo
In the band!
Originally Posted by Daniel View Post
any video of you rolling your dads ranger?
Old April 15th, 2011, 07:37 PM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
the axle shaft would not make the pinion leak .......its very easy to change just pop the yoke off and pry the old seal out and pop the new one in you do not need to pull the carrior
H.o.r.e
Old April 15th, 2011, 07:43 PM   #4
Daniel
SFA Ranger
Daniel's Avatar
Oh you're funny..
Ice and banked roads upnorth, plus a body lift and heavy cap = roof.
It didn't even roll, it just slowly tipped over on to the roof.
I'm sure he made it sound much worse then what really happened.
Now the real question, should someone with a 2004 pay for full coverage or be an idiot and have nofault?
I don't think its worth saving 20$ a month.
Old April 15th, 2011, 07:45 PM   #5
Daniel
SFA Ranger
Daniel's Avatar
The axle seal is leaking also. Not much but it is.
Watch the video, you can see the oil.
Old April 15th, 2011, 07:46 PM   #6
bigbchevy
missmrgreenagain
bigbchevy's Avatar
its a dana 30 i think they all leak lol just put a new shaft joint in and let it ROLL!
H.o.r.e
Old April 15th, 2011, 07:48 PM   #7
steveo
In the band!
Oh you're funny..
Agreed, shit happens and he is an idiot. I couldn't help myself, i have been waiting for months to get that jab in.
Old April 15th, 2011, 07:49 PM   #8
Daniel
SFA Ranger
Daniel's Avatar
Again. I have none of the tools needed for the job.
I do however have all of the parts minus the inner seal.
Old April 15th, 2011, 07:50 PM   #9
bigbchevy
missmrgreenagain
bigbchevy's Avatar
we will be in the barn tomorrow night if you wanna bring it over i will let you use the tools to fix it
H.o.r.e
Old April 15th, 2011, 07:53 PM   #10
Daniel
SFA Ranger
Daniel's Avatar
He is still being a douche bag over it. He wanted something with more room/power, I guess that worked out as an excuse.
I guess me having a really bad panic attack to the point of not being able to breath and puking several times, having gas all over me and scrapes/bruises doesn't matter.
For all he cares, he would probably be happier if I died.
Old April 15th, 2011, 07:54 PM   #11
Daniel
SFA Ranger
Daniel's Avatar
That would be cool. What time?
Old April 15th, 2011, 07:55 PM   #12
bigbchevy
missmrgreenagain
bigbchevy's Avatar
prob like five
H.o.r.e
Old April 15th, 2011, 08:04 PM   #13
Daniel
SFA Ranger
Daniel's Avatar
Sounds good.
If you pause the video at ten seconds you can see the small amount of oil from the axle seal leaking.
Old April 15th, 2011, 08:28 PM   #14
Daniel
SFA Ranger
Daniel's Avatar
I wonder how long it would take if I did both sides and the pinion seal.
The passenger side still has the original spicer joint that came with the one piece shaft I bought, but its still good.
Old April 15th, 2011, 10:38 PM   #15
littletrucker
I'd hit that
littletrucker's Avatar
That plastic thing in the picture is not that axle seal... it just stopped stuff from going in there, to change the axle seals you'll need to pull the carrier out, and they are in the pumpkin, and yes your whooped out u joint is prolly causing it to leak, replace it and see if it keeps leaking. The pinion seal would be an easy fix tho
Old April 15th, 2011, 11:58 PM   #16
Daniel
SFA Ranger
Daniel's Avatar
Thats the plan. I think it moving around is causing oil to slip by.
I have an idea of how to replace the seals, you need a special press of some sort correct?
I bought a duralast gold "wheel joint" as they called it and a timken pinion seal.
Good thing the u-joint is under warranty still, I just have to take the old one back and I get my money back.
I should have bought the better one in the first place but oh well.
Old April 17th, 2011, 12:19 AM   #17
Daniel
SFA Ranger
Daniel's Avatar
Thanks for the help Scott and other guys.
Hope everyone makes it home ok haha.
Old April 17th, 2011, 12:52 AM   #18
littletrucker
I'd hit that
http://jeep-xj.info/HowtoD30AxlesSeals.htm
something i found googling its how you do the seals, and a big socket like he has would work fine
Old April 27th, 2011, 11:19 PM   #19
Daniel
SFA Ranger
Daniel's Avatar
The inner axle seal isn't leaking now, so it had to be from the axle joint moving the axle shaft around.
Page generated in 0.37788 seconds with 81 queries
