U-Bolt supplier - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 15th, 2011, 12:21 PM   #1
FyrFyr
FyrFyr's Avatar
Default U-Bolt supplier
I'm new here but have been picking up a bunch of good info. I did not have good luck with a search to find a good U-bolt supplier in the Grand Rapids area for my 8.8 swap. I thought I would post this to help anyone else out. I ended up going to AB Spring Service at 4537 Roger B. Chaffee. I got 4 u-bolts made, nuts and washers for $24 in 15 minutes.
FyrFyr is online now   Reply With Quote
Old April 21st, 2011, 02:05 PM   #2
skife
skife's Avatar
when i did my 8.8 swap, i went to auto zone and bought a ubolt kit for a ford explorer. it was $19.95.
when i needed spring center pins i went to AB spring and got 2 center pins, threw a $100 bill on the table and the guy didn't want to make change so he just gave them to me. :)
Old April 21st, 2011, 08:24 PM   #3
curbdog17
Mini Van
curbdog17's Avatar
St.Johns Trucking in Muskegon is great too. I would stay away from Muskegon Brake, they will rape you on U-bolts.
Old April 21st, 2011, 09:20 PM   #4
bigblockford79
Big Block Ranger
bigblockford79's Avatar
I always use AB spring for U-bolts, they are the cheapest around and will make you anything you want while you wait. They are also open 24 hours, so if you know what you want and pay with a card they will let you pick them up from the night shift crew. The last set I got was about half price of the crappy taiwan set I could have bought at the local parts store.
Page generated in 0.15974 seconds with 35 queries
