3/4 ton Sonoma - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 14th, 2011, 07:11 PM   #1
daniel87lee
daniel87lee's Avatar
Default 3/4 ton Sonoma
i took a 79 gmc k2500 and a Sonoma built one sweet ride [IMG][/IMG]
Sorry for the lack of pics and info heres more
I took a 79 GMC K2500 Frame, Drivetrain, Motor and trans and Put a 96 Sonoma Body on the FUll Size frame
Started with the tear Down
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
The 79 Body Rotted right off but still had a solid frame sandblasted and paint the frame
Using a 400 SB with a TH400 with a np208
the 400SB has a edelbrock performer intake and edelbrock 750 Carb (limegreen)
[IMG][/IMG][IMG][/IMG]
Next was to set the cab where i wanted to take mesurements for my custom mounts
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
ended up smashing the window in the mounting process oops
i bolted the front clip to see if i had enough clearence to mount the full size radiator
[IMG][/IMG]
then came the box
[IMG][/IMG]
had to stuff boards in the wheel wells to couldnt find a jack big enough lol
[IMG][/IMG]
Got all mounts bolted on to the frame and the Body
[IMG][/IMG]
[IMG][/IMG]
Welded my new rear bumper on 6" C channel
[IMG][/IMG]
Disigned my new front bumper [IMG][/IMG]
took the front bumper from paper to the frame thats 6" C chennel to bolted to the frame not welded wanted to make sure i could pull it off when i put the 383 stocker in
[IMG][/IMG]
Cut the wheel wells out why Ethan was making sure the steering wheel was tight and all working order
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Mounted the Rings and Plate to my bumper all i have to due now is the sringer and supports
[IMG][/IMG]
[IMG][IMG][/IMG][/IMG]
Shes Running and Driving now but still not ready for the mud yet
[IMG][/IMG]
[IMG][IMG][IMG][/IMG][/IMG][/IMG]
Thats all i have for now ill keep you posted on more i things i have to do
Stinger for the front bumper
body work
paint
filler pannels so the po po cant see the huge 12" body lift lol
and new radiator
just add part of my new stinger and new
Painted the truck this weekend can miss it
Last edited by daniel87lee; May 31st, 2011 at 09:20 PM. Reason: Added More info and Pictures
daniel87lee is offline   Reply With Quote
Old April 14th, 2011, 08:05 PM   #2
adamzr2
numero douce undela
adamzr2's Avatar
all i see is a sonoma
adamzr2 is offline   Reply With Quote
Old April 14th, 2011, 08:10 PM   #3
bitchofanxj
Are you cooool maaaann?
bitchofanxj's Avatar
X2, need more pics and info man
bitchofanxj is offline   Reply With Quote
Old April 14th, 2011, 08:18 PM   #4
curbdog17
Mini Van
curbdog17's Avatar
I would bet its the one in the Avitar, more info, looks like a nice rig.
Old April 14th, 2011, 09:25 PM   #5
daniel87lee
got more add for you guys ill keep you posted on when more will be done
Old April 14th, 2011, 09:38 PM   #6
Freak
Wheelin the HD
Freak's Avatar
BDMT
Old April 14th, 2011, 09:39 PM   #7
boggin-machine
boggin-machine's Avatar
why a 12 inch body lift for real?
Old April 14th, 2011, 09:41 PM   #8
steveo
In the band!
cool.
Old April 14th, 2011, 10:30 PM   #9
daniel87lee
I had to go with a 12" body on the box the cab is like a 7" I had to do that cause the way the frame was compared to the sonoma frame this frame is the 79 and it's curves and the sonoma frame is flats that's y the 12" lift
Old April 15th, 2011, 01:34 PM   #10
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
While I like this, I would have cut out the curved areas of the 79 frame and made it fit around the new body.
I'm the man in White.
Old April 15th, 2011, 01:58 PM   #11
hellspawn
hellspawn's Avatar
Looks nice
hellspawn is offline   Reply With Quote
Old April 15th, 2011, 03:46 PM   #12
Strangler
Strangler's Avatar
I'm confused. If mounting this cab on this frame required a 32" body lift, why did you not just put te sbc and axles under the S-10?
Old April 15th, 2011, 04:13 PM   #13
bbaXJ
Yooper In Training
bbaXJ's Avatar
Rule #1: Don't apply logic to mud trucks
Rule #2: Hold my beer and watch this
Old April 15th, 2011, 05:17 PM   #14
Skooter_Built
Rule #3: Pour your beer on me cause Im on fire!!!
Old April 15th, 2011, 06:27 PM   #15
steveo
In the band!
Hey skooter, have you ever finished a project?
Old April 15th, 2011, 06:45 PM   #16
daniel87lee
I wanted to do something that I havent seen done much make mine diffrent than it's ever been done
Old April 15th, 2011, 08:48 PM   #17
bbaXJ
Yooper In Training
bbaXJ's Avatar
Not trying to be a dick, but you've never seen an S-10/Sonoma on a fullsize frame? Have you ever actually been to a mud bog?
Old April 15th, 2011, 10:23 PM   #18
jbsjunk
Little Member
jbsjunk's Avatar
I built a first gen S-10 several years ago on a K5 frame. Learned a lot of tricks building that. Made a nice driver too.
Old April 16th, 2011, 08:56 AM   #19
BlueBlazer98
Winning
BlueBlazer98's Avatar
..and look, no 12" body lift
BlueBlazer98 is offline   Reply With Quote
Old April 16th, 2011, 12:52 PM   #20
daniel87lee
I know what a mud bog is and I have been to dozens of them. I have seen s10s on full size blazer frames but never full size chevy frames left Uncut seen them on cut full size frames but everyone has there own ways of doing things
Page generated in 0.42916 seconds with 83 queries
