Misc Jeep Part(s) *feeler*XJ/MJ sexy winch bumpers. $375? (pics) - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 16th, 2011, 11:06 PM   #21
I suck cocks. Lots of them.
locally famous
do you know what it weighs? nice bumper
Old April 17th, 2011, 12:01 PM   #22
wellkevi01-KWO
wellkevi01-KWO's Avatar
Originally Posted by david92xj View Post
I would like the bumper better if you welded the shackle mounts all the way through it
It'd be kind of pointless to through weld the shackle mounts in 3/16" steel. If its gonna rip off then it'd tear the steel around the weld on the shackle mount (the welds tensile strength is greater then the steels tensile strength which is around 40,000lbs or so) and it'd do the same even if it were through welded. Also, just because the mounts would have weld on the front and back doesn't mean it'd be any stronger, cause the metal would lose some of its strength the more you weld in that one area. Mine and my buddies are only welded onto the face and they've been yanked on HARD in all directions. In fact, my buddies are 3/4" thick and they're only face welded onto 2"x4"x1/4" tube and one is actually bent and it didn't rip off. Really, the only way through welding the mounts would be any stronger would be if the bumper was made out of tube, and they went through the front and the back.
wellkevi01-KWO is offline   Reply With Quote
Old April 17th, 2011, 12:03 PM   #23
wellkevi01-KWO
I don't have an exact weight, but its around 80-100 lbs. I was gonna weight it, but it got mounted to the Jeep before I could. Lol and Thank You.
Old April 17th, 2011, 09:38 PM   #24
350cj5
Tiller Boss
350cj5's Avatar
The Front bumper is HOT! I saw another post askin about a rear one so that makes two of us interested in that.
350cj5 is offline   Reply With Quote
Old April 17th, 2011, 10:04 PM   #25
wellkevi01-KWO
For the rear bumper would you folks want it to be just a bolt on or have be for cut quarters, like this:
The bumper im designing for the rear, wraps around the sides where the bottom of the quarters are supposed to be and they stick out the side of the Jeep 2" to match the front. Also, its great if you ever end up exo-caging it. It adds protection and you'd have less body panel to destroy!
The bolt on one wouldn't wrap around, it would just match the contour of all the bends in the rear quarter.
also, thanks for the compliment!
Old April 18th, 2011, 02:13 AM   #26
HeavyArms
Hit the lights
HeavyArms's Avatar
Any thoughts on making zj bumper's?
xj bumper looks so sexy and id love one for my zj!
HeavyArms is offline   Reply With Quote
Old April 18th, 2011, 12:59 PM   #27
wellkevi01-KWO
Sizematters said he wanted one too and he may lemme design one using his ZJ, but that's still up in the air. Would you want a winch bumper or just a regular one?
Old April 18th, 2011, 01:08 PM   #28
trs80
Square Bear Killer
trs80's Avatar
I would like to have a rear that wraps around or replaces the lower rear qtr. Most Michigan XJ's have rust in that rear section anyways.
Or what about one like C-Rok 4x4 that covers the rear qtr with plate steel?
trs80 is offline   Reply With Quote
Old April 18th, 2011, 01:55 PM   #29
HeavyArms
Hit the lights
HeavyArms's Avatar
Id have to go winch. No point in getting a sexy new bumper if i cant have a winch to go with it!
Old April 18th, 2011, 03:12 PM   #30
wellkevi01-KWO
Ya, my XJ's rear quarters are rotting out, so they're due to be cut right off. I thought about doing that, but if you happened to take a good hit right there, it may bend those plates cause there's no support behind them, and then you're still left with a crushed quarter and a bumper that'd be a bitch to take back off.
Old April 18th, 2011, 03:49 PM   #31
BadDawg
BadDawg's Avatar
Enclose the ends for air tanks for airing back up after a day of wheeling??
BadDawg is offline   Reply With Quote
Old April 18th, 2011, 04:40 PM   #32
trs80
Square Bear Killer
trs80's Avatar
True. Im curious to see what you fab up for the rear. I wouldnt mind cutting out the rear qtr to add some real steel in its place. Any drawings of this design or just rolling with it (so to speak)?
Old April 18th, 2011, 07:05 PM   #33
wellkevi01-KWO
I don't have my Big Jeep Plans notebook(lol) with me, which has some rough sketches and dimensions in it, but I do have it all drawn out in AutoCAD, so the next time I get on the computer I'll take a pic of the drawing.
Old April 18th, 2011, 07:08 PM   #34
wellkevi01-KWO
Hmm...maybe. ill decided when I build it to see how much of a pain it is to fully enclose the ends. Theyre probably not gonna be big enough to hold alot of air though and I'd have to pressure test it.
Old April 18th, 2011, 07:41 PM   #35
SizeMatters
Sketchy, Son....
SizeMatters's Avatar
If it plays out right, Ill drop it off tomorrow so you can take it apart and figure out design. How many days would ya need it for?
SizeMatters is offline   Reply With Quote
Old April 18th, 2011, 08:11 PM   #36
wellkevi01-KWO
It'd probably take me 2 days to get the basic design of the bumper and the tie-in brackets.
Old April 18th, 2011, 08:12 PM   #37
SizeMatters
Sketchy, Son....
Alright, Ill give ya a shout when Im close.
Old April 18th, 2011, 09:16 PM   #38
trs80
Square Bear Killer
trs80's Avatar
More curious as to how big the piece going under the rear qtr would be? Similar in size to what you did for the front corner or larger?
Old April 18th, 2011, 09:51 PM   #39
wellkevi01-KWO
Here's a quick drawing I did with some dimensions.
Top and front
Side piece that replaces the bottom of the quarters.
Old April 19th, 2011, 02:04 AM   #40
HeavyArms
Hit the lights
HeavyArms's Avatar
And give me a shout when the first batch are ready for fitment!
Page generated in 0.42068 seconds with 82 queries
