Trailer wiring issue. brake light and turn signal don't work with head light on - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 13th, 2011, 08:06 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default Trailer wiring issue. brake light and turn signal don't work with head light on
The brake light and turn signals work when the headlights are off, but when I turn the headlights on, the turn signals and brake light no longer do anything, it just stays lit. Trailer lights are 2 wire, dual filament, and ground to frame.
Old April 14th, 2011, 06:58 AM   #2
kickstand
circling the drain
kickstand's Avatar
turn headlights off.
Old April 14th, 2011, 09:50 AM   #3
Quiefinator
go'til itsounds expensive
Check ground, don't you remember when my Sonoma did this? My tailights drew so much power my headlights went out.
Old April 14th, 2011, 09:58 AM   #4
booblinker
Sore and Tired 24/7
booblinker's Avatar
Fresh ground on truck and trailer side. From what I've read it sounds like I have the taillights hooked up to the bright filament, and have the brakes and turnsignals hooked up to the dim filament.
Old April 14th, 2011, 07:33 PM   #5
Mclovin
"The Situation"
Mclovin's Avatar
if your grounds are 100% then most likely what you said with Running lamps wired to Stop/turn wire.
Old April 14th, 2011, 08:02 PM   #6
booblinker
Sore and Tired 24/7
booblinker's Avatar
Swapped the wires and now all the lights work great.
Old April 14th, 2011, 08:15 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
been there.. gotta love it when the co. paints the trailer with the wiring on and you cant tell wire colors.
Old April 14th, 2011, 08:18 PM   #8
booblinker
Sore and Tired 24/7
booblinker's Avatar
Ha this was all me, new lights and new wiring, the light I bought didn't tell me which color was high and which was low, and I didnt even think about it.
Page generated in 0.20254 seconds with 47 queries
