2004 yukon wont start - any help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 13th, 2011, 09:46 AM   #1
ericeclark
Trick Fuck Jeeper
ericeclark's Avatar
Default 2004 yukon wont start - any help
My 2004 yukon will not start. after having front end work done the check engine light came on, i had the guys at good year in georgia clear the code before leaving the shop. I drove it for a while and shut it off to get gas the light came back on finished driving the 700 miles from georgia. Now the damn thing wont start. Smell of gas after turning it over. p0100 code shows up for MAF or VAF sensor. Dealer said those should not make it not start any GM people with help.
ericeclark is offline   Reply With Quote
Old April 13th, 2011, 09:54 AM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
My 04 did the exact same thing when the fuel pump pooped all over itself. There is a pressure relief on the fuel rail that is easy to get at. I drained the pressure, turned on the key, and I didn't have any pressure building.
Old April 13th, 2011, 10:53 AM   #3
bdd1469
bdd
bdd1469's Avatar
Rarely have I had a gm no start that wasnt a fuel pump.
Try having some one smack the gas tank with a rubber mallet,well you try to start it,sometimes the pump will lock up and this will make it run long enough to get it somewhere to work on.if it does start,dont shut it off.
You can take off air filter and pour a little bit of gas down the throttle body and see if it starts for a second.if you do that make sure you hold the throttle open,so the gas goes down the in the intake,doesnt puddle and start a fire.
Old April 13th, 2011, 10:57 AM   #4
ericeclark
Trick Fuck Jeeper
ericeclark's Avatar
Thank you for the help i will start there.
Old April 13th, 2011, 01:34 PM   #5
tctrojan17
Sexy and I know it.
tctrojan17's Avatar
Another thing is have a buddy turn the key to the run position and listen for the fuel pump kicking on and priming the system.
tctrojan17 is offline   Reply With Quote
Old April 13th, 2011, 01:43 PM   #6
clarkstoncracker
lol
This won't tell you anything. My pump in my yukon continued to run, even though it wasn't pressurizing the system.
Old April 19th, 2011, 06:30 PM   #7
twodollars
twodollars's Avatar
Use the parking brake much? My wifes does, and on her 04 the mechanism for the park brake rubbed through a harness and cut a couple of wires - bingo, no start.
twodollars is offline   Reply With Quote
Page generated in 0.17086 seconds with 44 queries
