International 184 tractor w/ 60" Woods Belly mower - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 12th, 2011, 09:28 PM   #1
osweezea
Default International 184 tractor w/ 60" Woods Belly mower
Still have it and would consider full/partial trades for a sport quad, 4x4 quad no smaller than 500cc, a two up quad, perhaps a boat if it works for our family. Or give me a shot on something else.
We are looking to sell our tractor only because we have bought a larger zero turn mower instead.
The tractor is an International 184 with a Woods 60" Belly Mower with hydraulic raise/lower.
We are asking $3000
The tractor runs great and has been a good mower for us. We used it to mow roughly 3-4 acres at our home. That's it. We have had it for about 2 years and the previous owner had redone some paint, replaced belts, and small things of that sort. He was very good with his maintenance.
In June of 2010 we had about $1900 worth of work done to it due to a previous owner who had removed a fuse, therefore causing some wiring to burn, and some to melt. Because of this, we had the tractor rewired at Aldermans. At the same time the pto switch, ignition switch, fuse holders, and pto clutch were all replaced. All wiring was removed and replaced. A new bracket was made to keep the pto from turning.
In May of 2010, a new coil replaced the old one and spark plugs were changed. Timing was adjusted and point gaps were set. Also at this time a compression test was done on all 4 cylinders and each was very good. Shortly after this, we wore through a brand new pto belt, and ended up having Aldermans replace the idler arm bracket and bearing, replace the worn belts with new, and realigned all the pulleys.
Basically this tractor is nearly completely rebuilt with the exception of the great running motor and transmission.
This tractor will also accept a snow plow, and I have one located if you would like more information on that. The plow would hook up to the existing hydraulics to raise and lower the blade also.
Feel free to call me at 810-691-3805 or email at osweezea@gmail.com. Thank you, Orea.
osweezea is offline   Reply With Quote
Old April 12th, 2011, 10:40 PM   #2
tracker97
tracker97's Avatar
very nice 184 glws
tracker97 is offline   Reply With Quote
Old April 13th, 2011, 07:04 AM   #3
chris1044
chris1044's Avatar
Curious....what's this thing weigh? Pictures make it somewhat hard to judge the size of it - looks like it'd be about the size of a Steiner 4xx.
Asking as I have some wet/soft places that get mowed.
Either way, GLWS...looks very clean
Old April 13th, 2011, 08:22 PM   #4
osweezea
Well, I have no idea what it weighs, and no idea what a steiner even is, but I'll check a few places online and see if i can come up with an estimated weight for you.
I also have a few wet spots I mow, Does pretty well actually. Those rear tires float over quite a bit.
Old April 13th, 2011, 08:30 PM   #5
osweezea
A quick Google search came up with this. Ill get a serial number off of it to specify what year it was made.
The International Harvester 184 Lo-Boy -- or Lowboy -- was a 1-liter, two-wheel-drive farm tractor. It was manufactured and sold between 1977 and 1980. The serial numbers from 1977 until 1980 were as follows: 43802, 46163, 48030 and 52339.
The total weight of the tractor was 1,620 lbs
There you go!!
Old May 4th, 2011, 09:04 PM   #6
osweezea
up
Old May 4th, 2011, 09:13 PM   #7
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
http://www.tractorhouse.com/list/lis...184&mdlx=exact
you have it priced right. nice machine.
Yetti
Old May 6th, 2011, 06:38 PM   #8
chris1044
chris1044's Avatar
Yes it is...a little big/heavy for what I need it for (somewhat wet area that I need to use it in).
Good luck with sale
Old May 15th, 2011, 10:26 AM   #9
osweezea
Thanks guys.
My exmark actually seems to do worse than this machine in the wet turf.
Still available.
Old May 30th, 2011, 09:26 PM   #10
osweezea
top
Old June 13th, 2011, 08:59 PM   #11
osweezea
up again
Old June 15th, 2011, 02:20 PM   #12
burl
DUCK-IT OFFROADING
burl's Avatar
Send a message via AIM to burl Send a message via MSN to burl Send a message via Yahoo to burl
Trade for a 99zr2 blazer its on here fs I need a mower!
burl is offline   Reply With Quote
Old July 15th, 2011, 08:30 PM   #13
osweezea
Sorry Burl, haven't been on in a while. Get ahold of me if you still have the Blazer.
Old July 23rd, 2011, 07:30 AM   #14
osweezea
up
Old November 6th, 2011, 04:09 PM   #15
osweezea
Still For sale. Could use a truck with snowplow or a snowblower.
Old December 8th, 2011, 08:00 PM   #16
osweezea
Old December 16th, 2011, 08:41 AM   #17
osweezea
I have found a great deal on some tools I want and am looking for a quick cash sale to fund those other purchases. This will be for a limited time. At the end of the month we will raise the price back to the original and sit on it if need be. If interested, contact me. Orea
Workshop was sold. Price adjusted accordingly
$3000
Old December 17th, 2011, 07:46 AM   #18
osweezea
back to the top
Old December 19th, 2011, 07:53 AM   #19
osweezea
up
Old December 20th, 2011, 06:55 PM   #20
osweezea
top
Page generated in 0.46982 seconds with 83 queries
