FreelinMX - 4x4 Extreme Mud! - 2011 Schedule (NEW classes) - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old April 12th, 2011, 02:04 PM   #1
freelinmx
Stroke It On the EastSide
Default FreelinMX - 4x4 Extreme Mud! - 2011 Schedule (NEW classes)
Extreme Mud! - FreelinMX - 2011 Schedule
NEW Class Structure, NEW Rule Structure (SEE BELOW)
Saturday, May 21, 1pm Showtime
Saturday, August 27, 5pm Showtime
Saturday, September 24, 1pm Showtime
Hosted by FreelinMX - South of Marlette, West off M-53 (VanDyke),
Between Barnes & Clifford Roads
53 acre facility located just south of Marlette (formerly S & A Raceway). Permanent heated showers/restrooms, FM 99.9 Announcer, bleachers, food, plentiful parking, playground.
Announcer, music, gift give-aways & MORE!!
Additional information posted on website!
Ann & Mike Konarski
FreelinMX
www.FreelinMX.com
info@FreelinMX.com
989.761.1301
8395 Cargill Road, Brown City, MI 48416 (for driving directions)
Stroke It On the East Side!
FreelinMX 2011 MudBog Classes
Class Type Tire Size
#1 Stock 36" & under
#2 Stock Type 36" & under
#3 Modified 36" & under
#4 Modified 40" & under
#5 Modified DOT any size
#6 Exotic DOT & Tractor - any size
Stock: Classes #1 DOT Type Tires
1. Plates & Insurance must match vehicle Vin#.
2. 4x4 vehicles only.
3. Engine must be factory option for vehicle.
4. Motor must be in stock location.
5. Flat beds allowed.
6. No gutting or stripping.
7. Any carb or fuel injection (to factory).
8. No nitrous or exotic fuels.
9. Must pull at least 15" of vacuum at 800 RPM.
10. No relocation of drivetrain components. Lift-kits allowed.
11. No open exhaust, no headers and must have some sort of muffler.
12. No Boggers, Terra, Scoops, or Cut tires.
13. Must be DOT approved tires.
14. This class is for stock factory trucks ONLY!
Stock Type: Classes #2 DOT Type Tires
1. 4x4 Vehicles Only.
2. Any motor & drivetrain combination allowed (no chain drives).
3. Motor on stock location of frame (front of engine must not be to the rear of centerline of front axle).
4. Flat beds allowed.
5. No gutting or stripping. Removable tops and tailgates may be removed.
6. Body swaps allowed. Must maintain wheelbase for body being used.
7. Any carb or fuel injection, naturally aspirated (unless factory equipped).
8. No nitrous or exotic fuels (bottle must be removed).
10. No relocation of drivetrain components fore or aft; such as engine, axles, & transfer case.
11. Suspension must be comparable to stock type (lift kits okay). No adjustable coil-overs unless factory equipped.
12. No open exhaust.
Modified Rules: Classes #3 & #4 DOT Type Tires
1. Vehicles may enter twice per class with a different driver but can only place once per class either longest run or fastest run.
2. Any motor and drive train combination allowed.
3. Stripping & gutting allowed.
4. Body and frame must be production made. Flat beds allowed.
5. Naturally aspirated- no nitrous- no exotic fuels (bottle must be removed).
6. Axles must be centered in wheel wells.
7. DOT type tires only, no cuts or tractor tires.
8. Must have approved driveshaft loops.
9. Suspension must be comparable to stock type (lift kits okay). No adjustable coil-overs,unless factory equipped.
10. Engines must maintain harmonic balance to centerline of front axle not behind.
Modified Rules: Class #5 DOT Type Tires
1. Engine, body, and chassis open.
2. Tire size open- no cuts, paddles or scoops.
3. No nitrous or injected alcohol (bottle must be removed).
4. Adjustable coil-overs acceptable.
5. Must have approved driveshaft loops.
Exotic Rules: Class #6 DOT & Tractor tires (any size)
1. Engine, body & chassis open.
2. Tire Size open. Cuts allowed. No paddles or scoops.
3. Any fuel naturally aspirated. Fuel Injection and nitrous okay. No
Blowers.
4. Must have approved driveshaft loops.
5. Adjustable coil-overs acceptable.
freelinmx is offline   Reply With Quote
Old April 14th, 2011, 09:17 PM   #2
dirty addiction
dirty addiction's Avatar
Sounds like a nice set up we will have make it over there some time.
dirty addiction is offline   Reply With Quote
Old April 14th, 2011, 09:26 PM   #3
jeepinRRT
jeepinRRT's Avatar
Freelin still owned by the Brown family? I haven't raced there in years, one of my favorite MX tracks when you had the over under and the super double was actually something that separated the men from the boys. Ahh, the good old days.
jeepinRRT is offline   Reply With Quote
Old May 17th, 2011, 02:30 PM   #4
freelinmx
http://www.freelinmx.com/images/MudBog-MAY_11-(web).gif
Link to 4x4 Extreme Mud! event this Saturday, May 21st.
FreelinMX
8395 Cargill Road
989.761.1301
www.FreelinMX.com
Owned and Operated by Mike Konarski (since 2000).
Old May 22nd, 2011, 03:09 PM   #5
jroberts#77
Fuck there goes the trans
jroberts#77's Avatar
any pics or videos from this?
jroberts#77 is offline   Reply With Quote
Page generated in 0.28759 seconds with 38 queries
