V8 TJ Build - Axle selection feedback - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 12th, 2011, 11:15 AM   #1
XJay
XJay's Avatar
Default V8 TJ Build - Axle selection feedback
Looking to get some opinions on which direction to take regarding axles to go under a TJ build. Here's the short story; have a '90 XJ that I've wheeled for the last 5 years, 350/700R4, D44/9", 37s. Loved the rig but hated the body damage it suffered every time out. Well I have the chance to restart, unwillingly however as the result of letting a friend take it for a boot and rolling it.
Picked up a '97 TJ and 350/4L60E out of '99 Yukon. Planning on doing a 3-link/4-link with coilovers. Been doing a pile of research and reading on which axles to run and have changed my mind 30 times in the last 30 days. The Jeep will be used for trailriding/crawling in the typical Michigan/Ontario environment, usually muddy, slippery rock. Would like to run a 42" tire, street use would be nice but not a necessity, I usually trailer everywhere I go.
I wheel with some guys on Rockwells and 44 to 49s. I thought about going in this direction as it would most likely be one of the cheapest, but I have decided against it for now as I would like the Jeep to be able to fit in a toy hauler at some point down the road.
I considered taking my 44/9" and putting good shafts up front and 35 spline the rear yadayada... but that front would still be a timebomb. I want it to be bombproof.
Then there's the tried and true 1 ton D60/14bolt, probably the best choice, I'm just not sold on it yet.
The option I'm leaning towards right now is dual 9 inches. I love 'em, always have, I think they're the best combo of strength vs weight. The question is would they hold up to a 42" tire with a V8 and a fairly heavy right foot. Could go 35 spline front and rear. The part I don't like is the $$$, and that the shafts would have to be custom (Moser or whatever), makes it difficult to carry spares. Would love to use Hi-9s but not sure if that's gonna be in the budget.
Looking for any other ideas, opinions, experience with the mentionned axles...
XJay is offline   Reply With Quote
Old April 12th, 2011, 12:01 PM   #2
I would think with good shafts, and aftermarket 3rd's and axle housings, they'd hold up fine. I'm looking at the same path for my Scrambler sometime soon.
Old April 12th, 2011, 12:38 PM   #3
I've been running a 35 spline True Hi-9 in the rear. No problems and it's worked out great. I have no desire to go back to a low pinion.
In the front, either do a HP-60 or a 609.
Any way you shake it, with your desired tire size, you need 35 spline axle shafts.
Old April 14th, 2011, 08:00 AM   #4
XJay
XJay's Avatar
Just out of curiosity, what kind of rough HP #s and tire size are you running? Also, Hi-9 claims that street use is not an issue, any experience with this?
It would be really tough for me to fit two Hi-9's in my budget, if I were to go high-pinion, should I go front or rear? Is there any strength difference between a High-9 and a regular LP 9-inch assuming shafts and all other components are the same?
Thx.
Old April 14th, 2011, 09:21 AM   #5
Thx.
39" Iroks & 39" red-labels, 6.0 LQ9, so about 350hp.
Old April 14th, 2011, 09:51 AM   #6
Yup, Hag gar remembers well. I've run it 20+ miles on the road at one time with no heat issues. Yes, it does seem a bit warm, probably in the 140* range.
To me, Hp is the best way to go period but if I had to do one or the other, it would be rear. With the front, most of the time you are able to work your dif around a rock, whereas the rear is a follower and is more likely to get hung up. In addition, with a HP rear, ledges are never a problem.
Regarding strength, go to the Hi-9 website. They have a whole section dedicated to comparing the strenght to other dif's.
Old April 14th, 2011, 10:11 AM   #7
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Thx.
You can get a Hi-9 for the rear and a high pinion D60 for the front, so you can have both.
Page generated in 0.26710 seconds with 44 queries
