Info Wanted on True Tracs Older Version VS Newer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2011, 07:44 AM   #1
Bo's Cj 7
Bo's Cj 7's Avatar
Default Info Wanted on True Tracs Older Version VS Newer
What is the difference between the older True Trac (Dana 44) it has 3 bolts through the carrier and the newer style has bolts from both side I think 6. I would assume they would not change them unless the first design had problems, tell me what you know
Bo's Cj 7 is offline   Reply With Quote
Old April 11th, 2011, 09:50 AM   #2
yyj87
yyj87's Avatar
If you talking about the Detroit truetrac, the newer ones operate much smoother than the old ones.
I have never had a "true trac" but I have had friends with them that loved them, two were older and made some noise but worked flawlessly.
Why not go for the locker vs LS, if you keep the tire pressures the same and adjust your driving slightly there not bad at all.
yyj87 is offline   Reply With Quote
Old April 11th, 2011, 10:06 AM   #3
Bo's Cj 7
Bo's Cj 7's Avatar
I have a powerloc in the front of my CJ now and its won't slip enough for driving on icy roads just want to push the front end so I am going to put the True trac in the front and the powerloc in the rear. Plus I paid $100 of the True Trac. I thought maybe to older version was week or something
Old April 12th, 2011, 06:00 AM   #4
Bo's Cj 7
Bo's Cj 7's Avatar
Morning Bump
Old April 12th, 2011, 07:06 AM   #5
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Have you tried making a call to Eaton's customer care center. They probably have an engineer that could give you the low down.
Old April 12th, 2011, 08:07 PM   #6
Bo's Cj 7
Bo's Cj 7's Avatar
I bought 4 of them for dana 44s and picked them up today on my way to work. Price was right
Old April 13th, 2011, 07:27 AM   #7
BigBlockBlazer
Axle breakin' 101
If your looking to sell one let me know, I may need one for a future build.
Page generated in 0.22120 seconds with 44 queries
