Problem with the 14bolt sf. Help! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 10th, 2011, 06:00 PM   #1
sandman101
Default Problem with the 14bolt sf. Help!
My friend is doing a disc brake conversion on his 14bolt sf. He was pulling the axles and noticed that the gears in the diff case are sloppy on the passenger were it sits in the diff. as you can see from the pics it's marring up the teeth on the gears. Silver lake trips are on hold till this is figured out. Him and I are not sure what's up with it so please check the pics and post your opinions on a solution. Thanks.
sandman101 is offline   Reply With Quote
Old April 10th, 2011, 06:04 PM   #2
sandman101
Some of the pics are kinda jacked up but you can see how messed up the gears are.
Old April 10th, 2011, 06:22 PM   #3
boggin-machine
boggin-machine's Avatar
blurry pics would help. get some compound and check the pattern. are the bearings junk?
Old April 10th, 2011, 07:37 PM   #4
sandman101
From the pics thats not residue from oil. the gears are actually marred on the last pic. Are you talking about the bearings on the end of the axle? if so no we checked them.
Old April 16th, 2011, 04:56 PM   #5
fullthrottle
2013 King of da Moustache
fullthrottle's Avatar
Send a message via AIM to fullthrottle
So spider gears are being abused somewhat. Get a carrier locker and call it fixed or get new spider gears, does't mean the carrier bearings are bad but it is always beneficial to check them while things are out.
fullthrottle is offline   Reply With Quote
Old April 16th, 2011, 05:01 PM   #6
Disturban
Disturban's Avatar
Lincoln lock that shit and go to silver lake
Old April 16th, 2011, 05:41 PM   #7
yyj87
yyj87's Avatar
^THIS + replace bearings and seals FTW
yyj87 is offline   Reply With Quote
Page generated in 0.16026 seconds with 44 queries
