how to tell if a torque converter is bad - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 8th, 2011, 07:30 PM   #1
chevy454
Landscaper from hell
Default how to tell if a torque converter is bad
Ok I have a 93 Chevy c1500 with a 350, I was driving home and it started taking long shifts down and back to higher gears. I pulled over and turned it off then start it back up after checking the trans fluid now it revs high in park and slams hard into drive, Can it be my trans or my torque converter?
chevy454 is offline   Reply With Quote
Old April 9th, 2011, 06:50 AM   #2
chevy454
Its also hard to start and the SES light it on when it is started
Old April 9th, 2011, 08:36 AM   #3
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Whats the SES code? Tranny fluid color and the level? That would be a good start!!
Old April 9th, 2011, 09:45 AM   #4
chevy454
I don't have a scanner to get the code and auto zone cant do it because its a OBD 1. The level of the fluid is at the mark. The color is normal and the fluid don't smell burnt to me
Old April 9th, 2011, 10:11 AM   #5
I suck cocks. Lots of them.
locally famous
sounds like a vacuum leak, crawl under there and have a look at your vacuum line going to the back of the trans
Old April 9th, 2011, 11:00 AM   #6
chevy454
Ok I pulled the codes by using a jumper wire, I got TPS circuit signal voltage high and Torque converter clutch solenoid stuck on any ideas on the TPS?
Old April 9th, 2011, 11:08 AM   #7
chevy454
Also where is the Torque converter clutch solenoid
Old April 9th, 2011, 04:32 PM   #8
chevy454
I replaced the TPS and it fixed the problem
Page generated in 0.18732 seconds with 47 queries
