05 Expedition Not Starting - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 7th, 2011, 08:14 PM   #1
hondadirtracer
Skymaster
hondadirtracer's Avatar
Default 05 Expedition Not Starting
My mom's 2005 Expedition w/ the 5.4 (83,000 miles) has decided to not want to start right away recently. When she goes to start it, it will start, run really rough and stall after about 5 sec of running. If she tries to restart it right away all it does is crank, not try to fire or anything. If she leaves the key in the on position for about 10 sec and then starts it, it runs fine. I'm thinking it's the fuel pump but not sure. The odd thing is that it does not do it every time she starts it. Any ideas?
hondadirtracer is offline   Reply With Quote
Old April 7th, 2011, 11:53 PM   #2
Quiefinator
go'til itsounds expensive
There could be a million things. Any CEL's? any chance to run a scan?
Why are you thinking fuel pump? Are you thinking that leaving the key in the ON position is building up enough pressure to run the truck for a short time. Can you hear it kicking on everytime? Check fuel pressure, should be easy.
Old April 8th, 2011, 05:11 AM   #3
Cool parts peddler
Ironman Offroad's Avatar
I would look for a corroded connection some where. Leaving the key on may be warming the connection enough to supply enough current to allow the truck to start. Start pulling connectors apart and inspecting them. Including the fuses in the fuse block and all ground connections.
Old April 8th, 2011, 11:32 AM   #4
hondadirtracer
Skymaster
No cel's. I could take it up to Oreillys to get it scanned. And yes that is what I was thinking. Have not listened for it yet. I'll see if I can rent a fuel pressure gauge.
Old April 8th, 2011, 03:29 PM   #5
Quiefinator
Ever changed the fuel filter? Unfortunately on these if they don't throw a code and you don't fix them for a living they can be difficult to diagnose. Good luck, post any findings and we'll try and help you out.
Old April 8th, 2011, 10:05 PM   #6
hondadirtracer
Skymaster
Fuel filter was done about 10k ago.
Anyone a tech at a Ford dealership not too far from Macomb?
Old April 10th, 2011, 04:41 PM   #7
hondadirtracer
Skymaster
Well it died today. When I was driving it today, it was acting like I was giving it throttle and then letting it go, like revving it up. It kinda stopped but then started again 5 min later. Took it to get gas and on the way back, it would not do over 10 and then it stalled. We can't get it restarted.
Anyone a tech at a Ford dealership near Macomb?
Old April 10th, 2011, 04:45 PM   #8
Bones
Bones's Avatar
did you check fuel pressure?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 10th, 2011, 05:05 PM   #9
hondadirtracer
Skymaster
I don't have a gauge. I was planning on renting one from autozone or oreillys.
Old April 10th, 2011, 07:34 PM   #10
hondadirtracer
Skymaster
Fuel pressure=0psi. When we sprayed ether into the throttle body, it started and ran for a few seconds before dying. When I crawl under the truck to listen for the fuel pump kicking on, I don't hear anything. And yes, I checked the fuse for the fuel pump.
Old April 11th, 2011, 05:33 AM   #11
88fordman
88fordman's Avatar
I work at a Ford dealer up here in Traverse City. Check the Fuel Pump Driver Module (FPDM). It is at near the back...I think you can see it through the left rear wheel
well. It will be bolted to the top of the frame crossmember. Those little bastards corrode away and then you get no fuel pump. There is an updated kit with studs that space the module away from the frame to help prevent corrosion like this.
88fordman is offline   Reply With Quote
Old April 11th, 2011, 06:43 PM   #12
hondadirtracer
Skymaster
It was covered with corrosion and when I was brushing it off, a hole opened up in the back of it.
Old April 11th, 2011, 08:20 PM   #13
88fordman
88fordman's Avatar
bingo
Old April 11th, 2011, 08:36 PM   #14
hondadirtracer
Skymaster
Originally Posted by 88fordman View Post
bingo
Thanks. We are going to the dealer tomorrow to get one.
Old April 12th, 2011, 09:28 PM   #15
hondadirtracer
Skymaster
Got the new FPDM, plugged it in, but did not mount it down yet. Tried to start the truck and nothing. I work tomorrow night, but I am going to mount it up on Thursday and see if maybe it just needs to be grounded to the frame.
Old April 14th, 2011, 09:12 PM   #16
hondadirtracer
Skymaster
Got it mounted up, unhooked the battery, unhooked the fuel filter, and re-hooked every thing back up and it runs finally.
Old April 15th, 2011, 07:15 AM   #17
Quiefinator
Sweet
Page generated in 0.47345 seconds with 74 queries
