need help on powerstroke - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 7th, 2011, 06:48 PM   #1
mudrunner456
mudrunner456's Avatar
Default need help on powerstroke
Ok so just bought a 97 powerstroke with an automatic yesterday. Already having issues. When driving down the road and truck in overdrive hit a bump and overdrive off light on shifter turns on and truck down shifts. mess with the button for a secound and the light turns off and truck shifts back in o/d. When the o/d is working properly the truck seems to shift fine, so i do not think the actual tranny is messd up, at least i really hope not. And when you press the button to turn off the o/d it does nothing unless u repeaditly press the button. bought a new button didnt change anything. Im guessing a short somewere. Or whatever actually shifts the truck in o/d as i think its electric o/d. Does anyone have some advice on were to start troubleshooting. No codes were thrown.
mudrunner456 is offline   Reply With Quote
Old April 7th, 2011, 06:54 PM   #2
jeepbrattt
New car smell.....Mmmmmmm
mine doesnt work on my powerstrok either, i guess it's a common issue. I found this link.
http://www.google.com/url?sa=t&sourc...kXTD44BAYINDJw
jeepbrattt is offline   Reply With Quote
Old April 7th, 2011, 07:10 PM   #3
mudrunner456
thats the thing mine works sometimes. but when it doesnt it disengages the o/d. if there is a way to bypass the switch i would do it.
Old April 7th, 2011, 07:15 PM   #4
jeepbrattt
If you google the "od switch not working on powerstroke" you will get tons of info. I looked into it when I bought mine awhile back. Some links say it works sometimes , others not at all. There was a few links that said check your wiring to the trans.. also one to the speed sensor
Google is your friend, ask it anything...the answers are always there somewhere
good luck
Old April 7th, 2011, 07:20 PM   #5
frdboy
frdboy's Avatar
Pull your steering column covers and check the wiring to the button, common place for the wiring to get rubbed through or break.
Old April 7th, 2011, 07:21 PM   #6
jeepbrattt
Exactly what that link says.
Old April 7th, 2011, 07:28 PM   #7
mudrunner456
ok thanks i will start at the sterring column
Old April 8th, 2011, 12:50 AM   #8
Quiefinator
go'til itsounds expensive
Watch those E40D's, even though they are heavy duty they will take a shit on you in a heartbeat. They do have some issues with the soleniod packs on the side, read up on those links and Good Luck!
PS They hate heat and dirty fluid. I know a lot of people run temp gauges and external filters in an attempt to string out the lifespan, last i checked they are pretty expensive to rebuild as well.
Old April 8th, 2011, 07:57 PM   #9
mudrunner456
ok got a new shifter today and changed nothing. going to look into the solenoid packs some more. I cant believe the trans is going out becuz when the o/d is engaging it works fine and the rest of the shifts seem normal too.
Old April 8th, 2011, 08:07 PM   #10
MARTIN HASSENGER
BRONCATRON
MARTIN HASSENGER's Avatar
Look at the gage when it's acting up what does it say. Does it do it when it's towing or just when ever.
MARTIN HASSENGER is offline   Reply With Quote
Old April 8th, 2011, 08:43 PM   #11
mudrunner456
does it just whenever. i have to think it is a short somewere. But i have no idea were to look. really wish i would have stuck to my guns when i started looking for a diesel and said i would not buy an automatic. This sucks
Old April 8th, 2011, 10:48 PM   #12
MARTIN HASSENGER
BRONCATRON
You'll love it in the end I thought about the same thing when I was buying mine but I went with the automatic and am glad I did, I do alot of long trips and enough town driving that a stick would be a hassle. if the trans is going spend the extra cash and buy a BTS TRANS it will pay for it's self there's nothing better.
Old April 20th, 2011, 07:15 PM   #13
fruzz
we todd did
fruzz's Avatar
shitty ford
fruzz is offline   Reply With Quote
Old April 20th, 2011, 09:05 PM   #14
firehawk
Live Action!
firehawk's Avatar
Originally Posted by fruzz View Post
shitty ford
Retard
Old April 22nd, 2011, 09:06 PM   #15
sjhenderson18
MEMBER
sjhenderson18's Avatar
swap in a 5 speed. I went through three transmissions in my 1997. With all the money I spent I could have just swapped a stick and called it quits! Good luck, hope you find something, try not to throw too much money at guessing and stay away from used transmissions!!
sjhenderson18 is offline   Reply With Quote
Page generated in 0.43819 seconds with 68 queries
