ranger wheels - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 7th, 2011, 08:04 AM   #1
cloud9tj
cloud9tj's Avatar
Default ranger wheels
what yr ranger wheels 15 inch will fit my 99 ranger
cloud9tj is offline   Reply With Quote
Old April 7th, 2011, 11:41 AM   #2
koochman450r
koochman450r's Avatar
i'm 99% sure that all rangers are 5 on 4.5. But i know for sure 93-2004 are. 2x4 and 4x4 are the same. Most all 2wd came with 14's though, beside splash's.
you won this battle.
Old April 7th, 2011, 11:56 AM   #3
lepp1892
WebWheeling1KeyAtaTime
lepp1892's Avatar
all rangers from 83 to current have a 5x4.5 bolt pattern.... so they should all fit....
lepp1892 is offline   Reply With Quote
Old April 7th, 2011, 01:02 PM   #4
GMKLR50
Broke wheeler
GMKLR50's Avatar
exploder, mustang, crown vic, grand marquis.......they will all fit
GMKLR50 is offline   Reply With Quote
Old April 7th, 2011, 01:55 PM   #5
cloud9tj
cloud9tj's Avatar
Default thanks
thanks for the quick response
Old April 7th, 2011, 06:28 PM   #6
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Even though the bolt pattern has been the same since 1983, not all factory wheels will fit every application. The exception is 1998+ 4x4 Ranger will not fit the front of a 1983-1997 4x4 Ranger. This is due to the change to a hub-centric wheel design to accommodate the new unit bearing style wheel bearings used on the A-Arm suspension.
If you have a 2wd you don't have to work about it, but since this is a 4X4 site you are probably looking for 4x4 wheels so this matters to you. Aftermarket wheels should all be made to fit any years, but make sure there isn't a year cut-off before you buy.
The newer wheels can be machined to clear the older style hubs if you really want the newer factory wheels.
Page generated in 0.18819 seconds with 41 queries
