D30/Yukon axles strength - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 5th, 2011, 03:11 PM   #1
AFRd_CJ5
AFRd_CJ5's Avatar
Default D30/Yukon axles strength
I've got a WT D30 in the front of my '76 CJ. Bought the housing and put all new Yukon shafts in it last year. Just wondering what this setup would handle power wise?
The reason for asking, is that there's a sand drag even this year that stipulates (2) DOT tires must be used, so I'm thinking about running paddles in the rear, and some 32x14 Boggers in the front. Just a little nervouse about running a heavy tire in those conditions.....
AFRd_CJ5 is offline   Reply With Quote
Old April 5th, 2011, 03:37 PM   #2
Bo's Cj 7
Bo's Cj 7's Avatar
By the looks of your avatar I think small and light front tires not big and heavy, I have had more trouble with ring and pinions than axles on my dana 30s
Bo's Cj 7 is offline   Reply With Quote
Old April 5th, 2011, 04:26 PM   #3
ajmorell
My concern would also be the R&P, it's not exactly what you'd want to be the weak point since taking it out royally f's you over.
Old April 5th, 2011, 10:28 PM   #4
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
A sand specific AT might be your best choice. They would be lighter than the boggers and they wouldn't dig either at the top end. Think about the desert traks, they work well because they don't dig after you launch, they just ride on the middle part allowing you to steer under power.
Best thing to do is to pick a set and be early for the test and tune.
Old April 6th, 2011, 05:54 AM   #5
AFRd_CJ5
AFRd_CJ5's Avatar
I run 14.50 Desert Trak's in the front now. The problem is, to run this event in the two classes I fit in, you have to run (2) DOT tires. So if I run paddles in the rear, I'm stuck running something DOT in the front, and I'm not buying something new just for one event.
Sounds like best bet, is to find something smaller/skinnier/lighter in the front I guess then.
Old April 6th, 2011, 07:59 AM   #6
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
What gears are you running? Most of the failures I've heard of have been 4.56 and up.
ckupq is offline   Reply With Quote
Old April 6th, 2011, 10:13 AM   #7
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Yeah by the looks of your avatar you dont need them to hook off the line
Old April 6th, 2011, 11:44 AM   #8
AFRd_CJ5
AFRd_CJ5's Avatar
4.56 gears in the front. So of course I fit in that "most failures" category
Old April 6th, 2011, 11:46 AM   #9
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Just keep the front tires in the air the whole lenght of the track and you'll be fine.
Old April 6th, 2011, 03:55 PM   #10
ajmorell
Fuck it, run it til it blows up then upgrade. I wouldn't throw any more money at the 30 myself.
Old April 6th, 2011, 04:10 PM   #11
RCM3691
No one said you had to run DOT tires with good tread, right? There's always someone on here trying to sell some worn out A/T tires. Find some that are suitably worn off and run those.
RCM3691 is offline   Reply With Quote
Old April 6th, 2011, 08:08 PM   #12
AFRd_CJ5
AFRd_CJ5's Avatar
If I could do that every time, I'd go wth that
I hate to hurt it for 1 event though. I don't think it will ever give out in the sand. We've put A LOT of power through stock D30's (and still do) in the sand with no problems.
That's exactly what I'll probably do. Find something small and worn out to run for that weekend.
Old April 6th, 2011, 08:14 PM   #13
IDIeselman
IDIeselman's Avatar
You could go to the local junkyard and be give for free a couple get to town tires "donut spares" Small,light and cheap. :)
Old April 8th, 2011, 07:54 AM   #14
junk90xj
ALLPRO AUTO
junk90xj's Avatar
what size rim do you use in the front?
i might have some worn out bfg at's you can have.
http://www.apalansing.com/
Old April 8th, 2011, 08:56 AM   #15
AFRd_CJ5
AFRd_CJ5's Avatar
I have some 15x10 and some 15x8 rims that I can choose from. I've got my regular 15x10 steel wheels with some 32" tires that I run on the street, and a set of 15x10's with 33x14 Boggers. Just didn't know how the front would hold up to launches off the transbrake on the bottle with a heavy rim/tire combo.
That's why I'm thinking of using the 15x8 rims and finding the smallest tire I can go with.
Old April 8th, 2011, 11:28 AM   #16
junk90xj
ALLPRO AUTO
junk90xj's Avatar
i have one 32" bfg mt 15" rim thats about 1/2 tread.
i also have two 33" bfg at tires that are pretty close to bald (free)
Page generated in 0.38583 seconds with 71 queries
