Gears Dana 44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 3rd, 2011, 11:41 AM   #1
AJ Hall
Kickin' Up MUD
AJ Hall's Avatar
Default Gears Dana 44
Just picked up a axle from ohearn on here and like he said the front R&P are a little worn.. Its a low pinion axle so will any dana 44 or 10 bolt GM or Ford front gears work? Its out of a 77 F250 and its a HD Low pinion. Thanks.
AJ Hall is offline   Reply With Quote
Old April 5th, 2011, 09:14 AM   #2
AJ Hall
Kickin' Up MUD
AJ Hall's Avatar
Old April 5th, 2011, 09:31 AM   #3
Renegade II
Coil springs are for pens
Renegade II's Avatar
You need gears specifically for a low pinion Dana 44, about $160 new.
Old April 5th, 2011, 11:55 AM   #4
AJ Hall
Kickin' Up MUD
AJ Hall's Avatar
damn alright thank you
Old April 5th, 2011, 12:27 PM   #5
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Depending on ratio, you can get new gears around $130
Page generated in 0.14192 seconds with 38 queries
