help 94 geo not run right - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 2nd, 2011, 10:21 PM   #1
haybob
Exclamation help 94 geo not run right
I parked my tracker for a few months. Now its not running right. Hard to start and when I get it running its missing, low on power, runs rich. I can't keep a steady rpm. Any help.
Tryed a diff computer. - no diff
haybob is offline   Reply With Quote
Old April 6th, 2011, 11:57 AM   #2
turnofftheradio
Have you checked the crank pulley bolt torque and inspected the keyway? That would be the very first thing I would do before throwing any $ or parts at it. if that is all good (94ftlbs, tdc real and lines up with the marks on pulley AND piston is reallyat tdc) then, is the check engine light on?
turnofftheradio is offline   Reply With Quote
Old April 6th, 2011, 04:38 PM   #3
spazbrevik
I would check your cap and rotor. you may have some moisture in there. I had a similiar problem with mine when I would hit puddles and after it sat for a while.
spazbrevik is offline   Reply With Quote
Page generated in 0.12597 seconds with 32 queries
