82 Scrambler Build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 27th, 2011, 04:46 PM   #1
RUSTYSPIKE9
RUSTYSPIKE9's Avatar
Default 82 Scrambler Build
Hi all...Building an 82 CJ8 here.
I have had it for about a year and finally doing something with it.
I picked it up in Paris MI for $2000
It is just a rolling frame, decent tub, and a bunch of random parts. Hope to make some real progress over the spring summer months.
Action Plan:
-Remove rust from tub and weld up the holes.
-Paint bottom of tub and then move on to the frame.
Name:	A beautiful garage.jpg
ID:	76480   Click image for larger version
Name:	Bad spot in frame.jpg
ID:	76481   Click image for larger version
Name:	Rear view frame.jpg
ID:	76482   Click image for larger version
ID:	76483   Click image for larger version
Name:	Tub front.jpg
Name:	Tranny prior to cleaning.jpg
ID:	76511   Click image for larger version
Name:	Tranny cleaning in process.jpg
ID:	76512   Click image for larger version
RUSTYSPIKE9 is offline   Reply With Quote
Old March 27th, 2011, 05:15 PM   #2
howell_jeep
Last Free Man
howell_jeep's Avatar
Looking forward to your build. What are the plans beyond removing rust and patching up the holes? What drivetrain?
howell_jeep is offline   Reply With Quote
Old March 27th, 2011, 06:09 PM   #3
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Subscribed, Ben.
Old March 27th, 2011, 07:44 PM   #4
RUSTYSPIKE9
After patching I will be painting the tub and frame. When that is completed, I will start assembling into one piece while cleaning and painting as needed.
Just picked up a half top for it over the weekend.
Drivetrain: I will be putting in what I have; 258, T4, & dana 300. Still deciding where to go from there. Maybe a larger V8??
Will be running stock axles for now w/ 2.73 gears.
Wanting to put a 4" or 4.5" lift with 33's and go with better gearing.
Originally Posted by 1x1_Speed_Craig View Post
Subscribed, Ben.
Thanks Craig...looking forward to working on it with you.....then it might actually turn out nice...
ID:	76514   Click image for larger version
ID:	76515   Click image for larger version
Old April 3rd, 2011, 11:49 AM   #5
RUSTYSPIKE9
I practiced welding yesterday for an hour or so. It was frustrating until I figured out the propper wire speed setting and heat. I was able to get a nice bead going near the end (well..nice for a beginner). It is tough not burining holes through such thin metal.
I hope to get some more practice in today. I have a hard time seeing where I am welding, so I might start in the right place, then veer off in the wrong direction.
Question: when welding in the floor pans, should I just tack weld it in or do I need to run a bead all the way around...I imagine that would do some warpage.
Old May 2nd, 2011, 07:56 PM   #6
RUSTYSPIKE9
Default Did some painting
I re-prepped my T-case for paint again as it has accumulated some rust from sitting so long.
I think it turned out well. It has a few coats of primer and paint.
Next on the agenda"
1. Remove axles and others leftover things from the frame.
2. Touch of the primer and prep for paint. (all items have been primmed some time ago)
3. Figure out what to do with the snapped off bolt for the skid plate, then fix.
4. Paint frame, axles, and Misc.
Hope to have done by the end of the month.
Just bought a spray gun and I have a air compressor coming tomorrow to test out.
Name:	Dana 300 Prepped.jpg
ID:	78384   Click image for larger version
Name:	Dana 300 Primer 1.jpg
ID:	78385   Click image for larger version
Name:	Dana 300 Mask 1.jpg
ID:	78386   Click image for larger version
Name:	Dana 300 Post Coat 1.jpg
ID:	78387   Click image for larger version
Name:	Dana 300 Post Coat 2.jpg
Name:	Dana 300 Post Coat 3.jpg
ID:	78389   Click image for larger version
Old May 2nd, 2011, 07:59 PM   #7
havoc1969
Wanderer
Send a message via Yahoo to havoc1969
I love cj-8's,,,, looking forward to watching this build!
havoc1969 is offline   Reply With Quote
Old May 3rd, 2011, 11:11 AM   #8
1x1_Speed_Craig
Simplify...
Looking good, Ben. You may want to consider clear-coating your aluminum to keep it looking nice, as well.
Craig
Old May 3rd, 2011, 07:01 PM   #9
RUSTYSPIKE9
Craig
Thanks Craig,
I still need to clean uo a few tough spots on the tranny. The alluminum looks kind of dull, does anyone know of anything that helps brings back that fresh alluminum look?
The link below is what I am thinking to use for my frame paint. Thoughts:
http://www.eastwood.com/ew-chassis-b...ss-quarts.html
or
http://www.eastwood.com/ew-chassis-b...in-quarts.html
Old October 30th, 2011, 06:56 PM   #10
RUSTYSPIKE9
Started working on the Frame this month.
It is fully dissasembled and I found another bad spot by the rear driver side spring hangar. I patched one of the holes and now have started to cut metal for the other. Unfortunatley I ran out of Argon so I am stuck till I get more.
I will get some pics up this week of my progress.
Old November 10th, 2011, 09:31 PM   #11
RUSTYSPIKE9
I made some progress over the last two weeks. I cut out the bad and welded it up. This is my first weld job....seems ok though. After I welded it, I hit it with a hammer and nothing would budge.
Tonight I started grinding down the frame to prep it for paint. Found someting odd.... someone fixed the frame before, but they welded a new piece inside the box frame and then put some kind of filler over it. I post a picture of after I removed the filler.
I only have after photos, because the before photos will not load. I used a different camera and I guess this sit does like the formating. I will see if I can fix it.
What should I do about this...I don't want to put filler back on it. Maybe I will just weld something over it and then grind it smooth.
My goal will be to have the frame painted this weekend. Before I get to that point I still need to do a few things:
-3 body mounts have been welded shut and I need to cut a new hole. Not sure what approach I will use.
-Figure out what to do with that wierd frame repair
-Wash the frame
-PAINT
Name:	Frame repair 018.jpg
ID:	85725   Click image for larger version
Name:	Frame repair 014.jpg
ID:	85726   Click image for larger version
Name:	Frame repair 023.jpg
ID:	85727   Click image for larger version
Name:	Frame repair 024.jpg
Old November 11th, 2011, 03:26 PM   #12
1x1_Speed_Craig
Simplify...
Good progress, Ben.
Regarding the frame, if you're not happy with the previous owner's patch job, I'd completely remove the filler, cut out the "shoddy" patch, and weld in a new one, as you have with other parts of your frame. Do it right now...you'll be thankful later.
Craig
Old November 17th, 2011, 05:31 PM   #13
RUSTYSPIKE9
Thanks Craig...advice taken.
I reworked that funky patch job from previous owner.
I also completed the painting of my frame this week!!!!!....it is so PURDY!
I used POR15...it looks quite nice I think.
Next on the agenda:
-Clean and paint axles
-Install axles, shackles, and springs (I would like to do a lift now, but too costly so I'll go with what I got)
-Clean and paint skid plate...then install.
Thats all for now.
Name:	Frame repair 027.jpg
ID:	85945   Click image for larger version
Name:	Frame repair 029.jpg
ID:	85946   Click image for larger version
Name:	Frame repair 032.jpg
ID:	85947   Click image for larger version
Name:	Frame repair 039.jpg
ID:	85948   Click image for larger version
Name:	Frame repair 048.jpg
Name:	Frame repair 049.jpg
ID:	85950   Click image for larger version
Name:	Frame repair 053.jpg
Old November 17th, 2011, 07:29 PM   #14
1x1_Speed_Craig
Simplify...
Looks GREAT, Ben. BTW, what are you going to top-coat the POR with? I have some POR-15 Self-Etching Primer that I probably won't end up using. It'll allow you to topcoat it with anything you want (I typically use Krylon). Give me a shout if you want the POR primer.
Craig
Old November 17th, 2011, 07:33 PM   #15
cerial
Direct Drive FTW
cerial's Avatar
Originally Posted by rustyspike9 View Post
i would like to do a lift now, but too costly so i'll go with what i got
soa?
Old November 18th, 2011, 02:18 PM   #16
RUSTYSPIKE9
Craig
I was not planning to top coat it because it won't really be exposed to the sun. Since you are mentioning it and are a 'Jeep Master' I assume this is something I should do ;-)
If you are not using the primer, then yes I would love to use it. Where can I buy Krylon?
Originally Posted by cerial View Post
soa?
SOA...so tempting...I don't think I have enough engineer in me to do it safely....thinking a 4-4.5in SUA.
Old November 18th, 2011, 02:27 PM   #17
1x1_Speed_Craig
Simplify...
You can have it then. Give me a call tomorrow if you want to pick it up. You'll definitely want to top-coat it. It'll start looking "chalky" almost immediately otherwise. I used the same process on my military trailer tongue, and am happy with the end result. You can look at it when you stop over.
You can get Krylon at Meijer (preferred ) or typically any hardware. Semi-Flat ends up having a very nice look.
Craig
Craig
Page generated in 0.40397 seconds with 75 queries
