1990 Jeep Wrangler wiht chevy 400 CID lifted whole or parts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 5th, 2006, 05:11 PM   #1
Gotmudd
Brew City 4X4
Gotmudd's Avatar
Location: New Berlin, WI (53151) and Big Rapids, MI(49307)
Send a message via AIM to Gotmudd
Default 1990 Jeep Wrangler wiht chevy 400 CID lifted whole or parts
Will sell entire vehicle or part it out as well. it is a 1990 jeep wrangler wiht a small block chevrolet. MAKE AN OFFER ON THE COMPLETE CAR OR PARTS.
Engine is a chevrolet 400 cid wiht estimated 400 hp rebuilt wiht low miles
Msd distributor
holley 670 modified for off road
High rise aluminum intake
chrome valve covers
milled heads-very slight but 89 or better octane
flat top hyperutetic pistons
comp cams xtreme offroad cam
comp cams valve springs
clevete 88 bearings through out
new crank not remaned
advance adaptors long tube headers and purple horny glass packs included
high volume high performance oil pump
all accessories included (alternator power steering pullies water pump etc)
Moroso high volume low pressure electric fuel pump
Conversion radiator in good shape however a few fins are bent near the bottom becasue i got the pressuer washer a bit to close, Its still good tho and straightening the fins is not an issue it can be done and work well or be use how it is.
Advance adaptors saddle engine cradle to mount chevy motor in jeep frame and poly mounts.
Transmission ax-15 rebuilt last year wiht less than 3000 miles.
advance adaptors bel housing adaptor to couple jeep transmission to chevy motor. Great combination for off road. Also include advance adaptors slave cylinder to make it work as well as stainless braided clutch hose.
Transfer case np-231 23 spline input. Just rebuilt last year with new chain less than 3000 on rebuild. Works great only about 70,000 on the case it self.
BUILT front driveshaft that is shorter than stock to fit in the chevy motor.
Rear drive shaft lengthend to fit conversion.
The conversion shortens the drive line so to front shaft is shorter and the rear is longer helping that terible rear angle found in most jeeps
Rough country 4 inch suspension lift kit wiht leaf springs and 2 inch shackle add-on and rancho rock crawler 8000 shocks.
Performance accessories 3" body lift
Dana 30 front end 3.55 wiht welded carrier and vacume disconnect. I hear bad stuff about welding one of these but i would have to say they never tried it it has been very reliable and never broke not to mention it gets great traction locked out and doesnt ever bind since with the manual disconnect switch.
Dana 35 rear end 3.55 wiht a limited slip carrier great shape
Pro-comp 35 x 12.5 x 15 mud terrains that are LIKE NEW! SERIOUSLY LIKE NEW!!!!! Mounted on 15X10 rims wiht great back spacing for a wrangler 5 on 4.5 bolt pattern.
Frame of the vehicle is probably the cleanest yj fram i have ever seen since most of its life was in california and it never saw the salt in the midwent in the winter since it has been a rec. vehicle for quite a while.
Monster Tach wiht shift light bought last year great shape near new.
Great off road front bumper however it has 1 dent in it. I hit a tree HARD and it just dented it. It is a TUFF bumper. It is very capable to get tugged ut of anything.
Body is in good shape still looks good, not a show car, but for the year and how it is used it looks nice. the hood has a good dent in it. some rust around hinges.
Windows all there and good
Gray Hard top in good shape. No cracks. Could easilybe painted any color.
Black bakini top wiht all accessories (rear window attachment and rear seat cover) used once almost new
MAKE OFFERS TO: meyerm7@fsuimail.ferris.edu or call 262-993-9578
Vehicle is located in Big Rapids MI but i travel to Milwaukee a lot of can also deliver parts or vehicle there or meet somewhere.
Gotmudd is offline   Reply With Quote
Old September 5th, 2006, 05:15 PM   #2
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
pics please
tcxtreme1000 is offline   Reply With Quote
Old September 5th, 2006, 05:18 PM   #3
BMFmike
meh.
BMFmike's Avatar
A 400 with dana 30 35 combo? This jeep sounds perfect for me.
Old September 5th, 2006, 05:35 PM   #4
Gotmudd
Brew City 4X4
Gotmudd's Avatar
well mike its got your t-case in it but its been rebuilt since.
Page generated in 0.24725 seconds with 35 queries
