1998 chevy k1500 transmission - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 24th, 2011, 09:56 PM   #1
cantafiof
drive hard and fast
Send a message via MSN to cantafiof
Default 1998 chevy k1500 transmission
i bought a chevy pick up with 230,000 on it and i was driving and it quit shifting into third, after that i paided a shop to rebuild the trans and after 1400, i got the truck back and the trans stopped shifting after ten miles, week after that i get it back and the truck makes it to 40 miles, and stops working, is there something that they are missing while rebuilding it
cantafiof is offline   Reply With Quote
Old March 24th, 2011, 10:07 PM   #2
vwBOY
it's how i roll
vwBOY's Avatar
check wire connections, check brake light switch for right adjustment if brake light switch is broke or out of adjustment the torque convertor wont lock up
vwBOY is offline   Reply With Quote
Old March 25th, 2011, 06:16 PM   #3
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
For one...stop taking it to that trans shop and get your money back
two, they're probably not filling it with fluid all the way when they put it back in
Old March 25th, 2011, 06:23 PM   #4
Tom
Because racecar
Tom's Avatar
Yes they are over looking something. It sounds like there is no cooler flow, possibly a blocked radiator of trans cooler. Also if it is the 3-4 clutch keeps getting smoked, there is a checkball capsule in the case that can go bad and cause a pressure leak. This causes the clutches to prematurely wear out. It also could have a bad epc solenoid not producing enough line pressure.
Old March 25th, 2011, 06:28 PM   #5
HPandThrottle
have fun or die trying
HPandThrottle's Avatar
internal electrical part a friend did this same thing like 6 times before they figured it out only affected od
HPandThrottle is offline   Reply With Quote
Old March 25th, 2011, 06:31 PM   #6
bigbchevy
missmrgreenagain
bigbchevy's Avatar
what shop?
H.o.r.e
Old March 27th, 2011, 04:57 PM   #7
cantafiof
drive hard and fast
algoma transmission and i will tell them everything to you guys said to look at thanks
Old March 27th, 2011, 05:07 PM   #8
cantafiof
drive hard and fast
i also noticed that there seems to be a dragging feeling right before the trans quits
Old March 28th, 2011, 04:30 PM   #9
efi355
if it been rebuilt n still has the problem i doubt uts the mechanical side of the trans... look at the electrical/ computer side of it. trans shops usually just reuse tthe solenoids n wiring n the computer is in the truck so if they bench it they dont even see it. my trans guy has a piggyback computer that he can run the whole trans with to rule out that kind of thing. look into something like that
efi355 is offline   Reply With Quote
Old March 28th, 2011, 05:12 PM   #10
skife
skife's Avatar
I'd give a good hard listen to tranny tom
Old March 28th, 2011, 05:35 PM   #11
cantafiof
drive hard and fast
they told me they will be tearing it apart tomorrow and that if it is my fault the transmission blew then i have to repay for it again, they said they think it is drivers fault but i drove the damn truck 60 miles, i think i should send it out for a second look
Old March 29th, 2011, 09:24 AM   #12
Tom
Because racecar
Tom's Avatar
Um no. Don't pay them again. They didn't fix it right the first 3 times. I would pull your truck out of that shop and take it somewhere else and get your money back. That is a line crooked trans shop owners use to not admit fault. It is 100% their fault that trans doesn't work.
Old March 29th, 2011, 10:24 AM   #13
skife
skife's Avatar
your not running huge power, shouldn't be your fault.
Old April 10th, 2011, 01:45 AM   #14
cantafiof
drive hard and fast
lmao truck is back i cant give it to much gas or it slips going into second and third but it is working for now.. sweet now i get to send it back
Page generated in 0.30112 seconds with 65 queries
