98 ZR2 sas w/xj long arm - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 3rd, 2011, 03:25 PM   #41
JACK48461
HEAVY D
new steering is in and all hooked up and working great now just have to finish the adapters to make the gm hubs work w the jeep brakes. And now that its all in and working time to make some new coil spring buckets to take the curve out of the springs & to add some bump stops. hoping to see the road in the next 2 weeks
JACK48461 is offline   Reply With Quote
Old April 8th, 2011, 11:33 AM   #42
JACK48461
HEAVY D
new brake lines are ran and working great. The new rear shaft is in & the coil spring buckets & bumper are in progress. should be ready to get an alignment and the front dif set up monday then good to go test it out next weekend
Old April 8th, 2011, 11:50 AM   #43
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Looks good, where did you get the flange for your tcase?
Old April 8th, 2011, 12:03 PM   #44
Tex
Tex's Avatar
Looks Nice, any way to get a brake down on the parts list.
Tex is offline   Reply With Quote
Old April 8th, 2011, 03:20 PM   #45
JACK48461
HEAVY D
the t-case adapter is @ synergyoffroad.com & im planning on making a complete list of parts , steel and everything i used & where it was from after i'm 100% done so in a week or to i'll post it
Old April 8th, 2011, 11:05 PM   #46
Tex
Tex's Avatar
That would be great.
Old April 10th, 2011, 10:34 PM   #47
JACK48461
HEAVY D
a few pics of the new buckets and just a lil fucking around on the trailer still need an alignment shocks, sway bar , and a few other misc things but its getting there
Old April 15th, 2011, 03:25 PM   #48
JACK48461
HEAVY D
New shocks are in and looking good . New brake lines are ran & sway bar quick disconnects are in. Bleeding the brakes tonight and going for the maden voyage. Front diff gets set up monday then just waiting on a new front driveshaft to try out the trails.
Old April 15th, 2011, 03:40 PM   #49
2fst4you
2fst4you's Avatar
why so tall?
Old April 15th, 2011, 04:01 PM   #50
JACK48461
HEAVY D
I went tall enough to clear the tires in all 4 corners incase i bottom out flexing to save the body. If i was gonna mud it and not plan to flex it much i wouldve went w stiffer springs & kept it a lil lower. It ended up being 14"s of lift in the front 13" rear but im in the middle of fabing a front bumper and then gonna start some rock sliders next. I just have to find a deal on a tubing bender first.
Old April 18th, 2011, 02:05 PM   #51
JACK48461
HEAVY D
Well the maden voyage was partially successful. The steering steers like shit even with all new components and an alignment i have bump steer that will rip the wheel out of your hans but other than that it rides great. I ordered the teraflex high steer kit that'll be in on thursday this week. does any one else have any other ideas. I do have a good stabilizer on there now my issue right now seems to be to much angle on the drag link & to much flex in the linkage pieces
Old April 19th, 2011, 01:42 PM   #52
ben
nmu trailcats
ben's Avatar
what angles are your draglink and track bar at? are they parralel with each other
ben is offline   Reply With Quote
Old April 19th, 2011, 04:17 PM   #53
JACK48461
HEAVY D
they appear to be almost parralel but i notice after i had someone turn the wheel for me that my steering would twist and load up when turning. my angle is almost 40 degrees on my draglink bc the truck has 14" of lift. So i ordered a high steer for it now & im hoping to get the drag link a little more leveled out then ill run a line on my track bar again to reset the height on the track bar. Its hard to judge by looking at it with out running a line from bolt to bolt on my track bar because the extended track bar is adjustable and is in an S shape.
Old April 20th, 2011, 01:01 AM   #54
2fst4you
2fst4you's Avatar
u need to run bump stops lower it and run a bigger tire maybe even trim. low cog is ur friend
Old April 24th, 2011, 10:53 PM   #55
JACK48461
HEAVY D
Put a jb high steer on this weekend worked out nicely drives 10x better than before still have some slight bump steer. other than that no biggy it was an easy install and just need to make up some new sway bar brackets. And i need to get a 2" drop pitman instead of my 4" i have on it and that should put me perfectly parralell w the track bar and hopefully eliminate the last of the bump steer. Finally took it out & up to 55 and it def rides great no complaints there but i will most likely regear to 4.56's this fall. I'll just have to see how summer goes.
Old April 24th, 2011, 11:16 PM   #56
14x4
14x4's Avatar
Looks good man! I can't wait to get my S10 SAS'ed!
14x4 is offline   Reply With Quote
Old April 26th, 2011, 05:21 PM   #57
JACK48461
HEAVY D
It's almost complete just waiting on the front drive shaft now
Old April 30th, 2011, 10:09 AM   #58
JACK48461
HEAVY D
thinking about doing a 5.7 vortec not sure yet though trying to talk myself into it. I found alot of easy swap kits just need to find a decent 96-99 truck w motor to pull the ecm out of and the main engine harness for the extra 2 injector pins.
Old April 30th, 2011, 11:47 AM   #59
knaffie
knaffie's Avatar
No need to get the ECM, you can use yours, just get it reprogrammed. Same with the harness, just have it modified to include two more injectors. If you happen up on a deal with the ECM and a harness, it may be cheaper that way, but don't let it be a show stopper.
There is a log of good swap into on ZR2USA.com. The 5.7 swap has been done many, many times now.
Old April 30th, 2011, 04:37 PM   #60
JACK48461
HEAVY D
Yea ive been reading a few of those on there. I've done a few 5.7 swaps before with throttle body s-trucks but this will be my first w a vortec. I did see theres one that was really helpful the guy has step by step nice detailed pics and part numbers. I would just gear the hell out of my truck and run the 4.3 but i like to drive it to not just wheel it. So idk i'm kinda at a toss up.
Page generated in 0.44675 seconds with 83 queries
