Spider gear ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 23rd, 2011, 12:18 AM   #1
97 jeep Cherokee
97 jeep Cherokee's Avatar
Default Spider gear ?
I'm putting 4:10s in my Dana 30 and I was wondering in the new carrier can I use my old spider gears from my stock carrier. My stock ratio is 3:55
97 jeep Cherokee is offline   Reply With Quote
Old March 23rd, 2011, 07:15 AM   #2
upchuck
upchuck's Avatar
Going by 4wd Hdwr parts listing there's no differentiation. Difference in carriers must be just the flange for the ring gear?
upchuck is offline   Reply With Quote
Old March 23rd, 2011, 08:25 AM   #3
orionn
orionn's Avatar
Yes, you use your old spider gears, side gears, and cross pin.
Changing the gear ratio does not affect the spider gears or side gears.
Even if you go to a different axle shaft spline count, the spiders would stay the same.
hth
orionn is offline   Reply With Quote
Old March 23rd, 2011, 08:27 AM   #4
orionn
orionn's Avatar
even if you go to a different spline count, the spiders would stay the same.
hth
Correct, the carrier break refers only to the offset of the bolt flange for the ring gear.
Old March 23rd, 2011, 11:36 AM   #5
97 jeep Cherokee
Thank you guys for the help
Old March 23rd, 2011, 01:02 PM   #6
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
hth
Have you hit your head?
If you go with a different axle shaft spline count you would need new spider gears to match the new spline count.
Also, JK spider gears are not compatible with the new carrier you'd need for 3.73 and up (this only relates to changing gears in a JK and not specifically to do with this thread).
Old March 23rd, 2011, 03:07 PM   #7
orionn
orionn's Avatar
No I have NOT hit my head....well actually I have in the past......
I suspect that what you may call a spider gear I call a side gear (the gear which has the splines cut into it).
So, for an axle spline count change you need new Side gears with the proper spline count for the axle shaft, the spiders should be fine unless the tooth count on the side gear changed for some reason.
I dont know about the JK axles you speak of, I have no experience with those.
Old March 23rd, 2011, 03:32 PM   #8
correcto..
side gears = big splined ones
spider gears = little ones on the cross shaft
Old March 24th, 2011, 10:53 AM   #9
Jeeperz Creeperz
GL 4x4 Vendors
correcto..
Okay, if you want to get all "technical"....
Spider gears are a set of gears in the differential which allow for a speed differential between the axle shafts when turning. You can call them differential side gears and spider gears if you like, but they're a set of gears that ride on two non-intersecting shafts that touch each other at right angles, unlike spur gears.
Try to buy one side gear - I'll bet it comes with three other gears (unless you're buying it used).
My point was that while most "spider gears" can be taken out of one carrier and inserted into another carrier (for same differential but for different gear ratio), there are some differentials starting to appear on the market that you cannot do this with, most notably the 8.5 vs 8.6 differential, the 8.6 differential (early vs. late), and the JK Dana 30.
Page generated in 0.28357 seconds with 50 queries
