mini spool - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 22nd, 2011, 10:31 PM   #1
vwBOY
it's how i roll
vwBOY's Avatar
Default mini spool
i have an open diff andlooking at the price of a locker to the price of a mini spool it is going in a gm 10 bolt what do you guys think it is my summer ride i know the mini spool locks perminetly but it is alot cheaper than a eaton e80 locker
vwBOY is offline   Reply With Quote
Old March 22nd, 2011, 10:35 PM   #2
Shotgun
I only wheel with boats.
Shotgun's Avatar
Weld it!
Old March 22nd, 2011, 10:38 PM   #3
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
Originally Posted by Shotgun View Post
Weld it!
Even cheaper than a mini spool with the same effect.
Old March 22nd, 2011, 10:41 PM   #4
vwBOY
it's how i roll
vwBOY's Avatar
Weld it!
not as strong as a mini spool
Old March 22nd, 2011, 10:45 PM   #5
creeping death
I'm that guy.
creeping death's Avatar
if it's done right you wont have a problem.
Old March 23rd, 2011, 07:36 AM   #6
jeepinitup
Car Ram Rod!
jeepinitup's Avatar
are you goin on the road alot, or mainly off road?
jeepinitup is offline   Reply With Quote
Old March 23rd, 2011, 07:37 AM   #7
orionn
orionn's Avatar
I agree, but 'Done Right' is open to interpetation.
The last one I welded up I used a tecnique called 'Fozzy Locked'
I ran it for over 2 years with no issues, on and off road.
Search for Fozzy Locker for pictures and more info, but here is the basics of it:
With the welder, you fill in the valley's on the side gears so the spider gear teeth will contact the weld as the axle turns. This will allow about 15 degrees or so of rotation befor the axle locks.
The trick here is to make sure the spider gear teeth all contact the side gears welds at the same time so you dont load the gear un-evenly.
Simple really, and this way you dont destroy the carrier by welding on it.
The main advantage is in turnning on pavement, you start into the turn a bit befor the axle locks up and drags the outside tire. It helps on wet pavement.
orionn is offline   Reply With Quote
Old March 23rd, 2011, 09:22 AM   #8
littletrucker
I'd hit that
littletrucker's Avatar
With the welder, you fill in the valley's on the spider gears so the side gear teeth will contact the weld as the axle turns. This will allow about 15 degrees or so of rotation befor the axle locks.
The trick here is to make sure the side gear teeth all contact the spider gears welds at the same time so you dont load the gear un-evenly.
X2 I welded my rear spiders "fozzy style" and i love it, its "easy" you can weld the spiders out of the carrier minimizing splatter, you cant really tell it has a little play in it and it works!
Old March 23rd, 2011, 09:32 AM   #9
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
My 14 bolt has been welded for 7 years know! No problem w/ it what so ever!! Before it had a Detroit in it and then that broke, it broke two days after the warranty was up!!
Old March 23rd, 2011, 10:09 AM   #10
alboy79
Where's your loyalty lie?
alboy79's Avatar
I've ran mini spools and weldeds on and off road. I would do either cause they are so cheap. If you go mini spool get the chromoloy cross pin. It helps.
alboy79 is offline   Reply With Quote
Old March 23rd, 2011, 10:18 AM   #11
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
This right here to me screams that you sir are in fact a fucking retard.
Old March 23rd, 2011, 10:34 AM   #12
littletrucker
I'd hit that
I fully expect everything else to break before my "fozzy locker" gives me trouble.
Old March 24th, 2011, 09:35 PM   #13
RubberDuck
RubberDuck's Avatar
We have welded for years, and have broke more shafts than our welds. I would stay away from welding or mini-spooling the front. I've had good luck with lock-rights for the front.
RubberDuck is offline   Reply With Quote
Page generated in 0.44739 seconds with 62 queries
