SOLD King pin 60 Ford - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 22nd, 2011, 02:52 PM   #1
Ford rules
Ford rules's Avatar
Default SOLD King pin 60 Ford
For sale is a ford kingpin 60 driver drop dually axle. Complete hub to hub. i believe it has 4.10 gears. Has typical surface rust but in good condition. $800 Make me an offer need to sell asap!
Txt/call 810 623 4615 for fastest response.
My name is Rob.
Brighton MI
Will trade for coil overs.
Ford rules is offline
Old March 22nd, 2011, 06:41 PM   #2
duster
what year
duster is offline
Old March 22nd, 2011, 08:13 PM   #3
Ford rules
Ford rules's Avatar
i believe its a 89 it is kingpin so there all about the same as far as i know for the king pins.
Old March 23rd, 2011, 09:25 AM   #4
Ford rules
Ford rules's Avatar
Ttt
Old March 24th, 2011, 07:28 AM   #5
Ford rules
Ford rules's Avatar
make offers!
Old March 24th, 2011, 04:41 PM   #6
Ford rules
Ford rules's Avatar
From an 89 has 4.10 gears heres some pics.
Old March 24th, 2011, 08:54 PM   #7
axle_eater306
Ford Fanatic
axle_eater306's Avatar
King pin dana 60's are NOT all the same 78-79 ford D60's had the differential housing further away from the driver side steering knuckle. The D60's 1980 and after king pin and ball joint take the same shafts, due to change in body styles and more specifically frame widths, take notice in how little axle tube is between the casting of the pig and knuckle in the picture, barely room for that sway bar mount let alone any other sort of brackets for a custom build. this is why 78-79 D60's are considered the holy grail of "junk yard" axles, lots of room for brackets, plenty of room to narrow them up, 35 splines and king pins.
i'm always looking for D60's tho, preferably not dually but they can be switched over. I'll give ya 300 for it.
axle_eater306 is offline
Old March 24th, 2011, 09:05 PM   #8
Ford rules
Ford rules's Avatar
I am aware of the differences between the 78/79 d-60's thanks as im sure we all are on here.
This is not a 78/79 d-60 as you have pointed out thanks.
Geuss i should have said make reasonable offers...
Old March 24th, 2011, 09:13 PM   #9
axle_eater306
Ford Fanatic
cant blame a guy for trying low ballin ya, SOMETIMES it works........
Old March 25th, 2011, 01:41 AM   #10
ben
nmu trailcats
ben's Avatar
whats the measurement centerpin to centerpin for the spring mounts?
ben is offline
Old March 25th, 2011, 04:08 PM   #11
Ford rules
Ford rules's Avatar
Ill try and get that to you asap, the axle isnt at my house ill do some research and try and find out though.
Old March 26th, 2011, 03:10 PM   #12
Ford rules
Ford rules's Avatar
Ttt
Old March 27th, 2011, 03:06 PM   #13
Ford rules
Ford rules's Avatar
Ttt
Page generated in 0.40729 seconds with 62 queries
