ax 15 conversion - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 20th, 2011, 11:28 PM   #1
97 jeep Cherokee
97 jeep Cherokee's Avatar
Default ax 15 conversion
im putting a yj ax 15 in my cherokee and i was wondering if the yj shifter will work for a xj and what all do i need for the conversion this is my first one i know i need clutch,pedal,and i forget the rest. so please help me
97 jeep Cherokee is offline   Reply With Quote
Old March 21st, 2011, 05:47 PM   #2
97 jeep Cherokee
I need some help I was told the yj ax15 cocked the tcase up a bit so I might have clearance issues and also what tcase should I use
Old March 21st, 2011, 05:49 PM   #3
MiNi Beast
MiNi Beast's Avatar
use a 231 tcase, no big deal on clearance, a little hammer finesse will take care of it, not much needed though, are you going from a auto to a manual? what year is the XJ, assuming it is a 97 but double checking, and what year ax-15?
Old March 21st, 2011, 06:00 PM   #4
97 jeep Cherokee
Yeah auto to manual and it is a 97 and the ax15 is outta a 91 yj could the tcase I have now off my aw4 work on the ax15
Old March 21st, 2011, 06:01 PM   #5
MiNi Beast
MiNi Beast's Avatar
yes both is 23 spline
Old March 21st, 2011, 06:03 PM   #6
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
if the np231 is a 23 spline in will probably work but you may have to adapt your shifter.
tcxtreme1000 is offline   Reply With Quote
Old March 21st, 2011, 06:03 PM   #7
97 jeep Cherokee
What all do I need to do the conversion and where should I get it I'm trying to do it all right the first time
Old March 21st, 2011, 06:05 PM   #8
97 jeep Cherokee
Ok would the yj shifter work if not what shifter should I use
Old March 21st, 2011, 06:10 PM   #9
MiNi Beast
MiNi Beast's Avatar
yj shifter will work just be a bit longer. have to eliminate the auto harness for a mans one and need a manual computer, need clutch/brake assembly, fly wheel from a 97+ manual with a CPS, would be better to find a external slave bell-housing setup and run that.
Old March 21st, 2011, 06:12 PM   #10
MiNi Beast
MiNi Beast's Avatar
custom pilot bushing as well as the 91 trans input shaft has a smaller diameter shaft tip as the crank hole was smaller till 92+ when they opened it up to use a larger diameter shaft.
Old March 21st, 2011, 06:14 PM   #11
97 jeep Cherokee
Witch ways easier and I just need to find a 97+ manual at the junk yard I could never find one at Lkq
Old March 21st, 2011, 06:15 PM   #12
97 jeep Cherokee
Ok thank you for all thee help anything else u think I'll need let me know
Old March 21st, 2011, 06:15 PM   #13
MiNi Beast
MiNi Beast's Avatar
you can find 97+ ax-15 easy enough just cost a bit
Old March 21st, 2011, 06:20 PM   #14
97 jeep Cherokee
So should I just use the 91 yj one I have or get a 97 from a xj I'm looking for a summer project
Old March 21st, 2011, 06:25 PM   #15
MiNi Beast
MiNi Beast's Avatar
depends how much tiddly you want to do with it. If plan on taking some time and doing it and not just trying to slap it in in a weekend then just use the 91.
Old March 21st, 2011, 07:05 PM   #16
97 jeep Cherokee
Ok yeah it might be next summer with all the custom work I'm go na have to do only if my aw4 worked right
Old March 21st, 2011, 07:35 PM   #17
MiNi Beast
MiNi Beast's Avatar
could just pick up a aw4 cheap and install a lock up switch for the coverter, be doing that in mine, drove with a ax-15 for first three years, I loved it, but auto is nice when climbing rocks and when the girl wants to drive.
Old March 21st, 2011, 07:43 PM   #18
97 jeep Cherokee
Right yeah mine works right when it wants I have to drive it like a manual it's not the tps or the solenoids I don't think if I get it spinning on ice or something it works some times and the Rpms are off when I drive it manual and when it works the Rpms are right
Old March 21st, 2011, 07:44 PM   #19
97 jeep Cherokee
I have two other aw4s I tried the 2000 but it wouldn't fit idk if the 96 will or not got any ideas what to do
Old March 21st, 2011, 08:28 PM   #20
MiNi Beast
MiNi Beast's Avatar
96 might, My aw4 is the same way as you have to drive it manually shifting the gears, somedays works fine, looked for what it might be but no direct answers, was a thread on it just a bit ago but not much for answers that helped me either.
Page generated in 0.41509 seconds with 83 queries
