727 netural safty switch help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 20th, 2011, 10:38 AM   #1
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
Default 727 netural safty switch help
got the 318 installed in my 89xj and also put a b&m megashifter in. i am using a 727 trans out of a 86 ramcharger. i know the netural safty switch has 3 wires. i know that the reverse lights have to get tied into it and also i am assuming a wire from starter relay but not for shure. i have found the wire running from under dash that goes to reverse light. anyone know what the other 2 that have to go to switch. also what wire from colum or relay have to go down there or a wire diagram of anykind. thanks for any help
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old March 20th, 2011, 06:01 PM   #2
mprmn08
mprmn08's Avatar
reverse lights, starter, and i think the third is a ground. not sure though, been awhile since i wired one.
Old March 20th, 2011, 07:15 PM   #3
v2win
v2win's Avatar
Middle is grounded when in Park & Neutral.
The outer two, red and white, connect when in Reverse - inline with reverse light circuit.
v2win is offline   Reply With Quote
Old March 20th, 2011, 08:33 PM   #4
CHEROKEEMUDMAN01
mellow yellow
ok so the middle wire goes to ground on the starter relay right?
and one outer wire will be key on power
the other wire will go to reverse light circuit
did i understand this right?
Page generated in 0.17131 seconds with 35 queries
