302 locked up / wrong firing order? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 20th, 2011, 11:10 AM   #1
chevyk10
FORD / GM
chevyk10's Avatar
Default 302 locked up / wrong firing order?
So long story short, this dumbass kid was trying to figure out the firing order on my friends 302 after they rebuilt it, and he wound up hooking the spark plug wires up wrong and the motor fired then locked up solid. (Never saw the kid again after that btw) The motor is completely built up and now has been sitting for 2 years since then. My friend told me he'd sell it to me for $250 bucks cause he doesn't wanna mess with it anymore. Just wondering if anyone has any idea why it would have locked up? Definetly gonna buy it though to replace the 300 six in my F150.
chevyk10 is offline   Reply With Quote
Old March 20th, 2011, 11:12 AM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
ive never seen one lock up from that
H.o.r.e
Old March 20th, 2011, 11:18 AM   #3
firehawk
Live Action!
firehawk's Avatar
I know a guy that went to start his newly rebuilt engine and it locked up, turned out someone dropped a nut or bolt down the intake and it sat on top of a piston and got pressed up to the head and locked the motor up.
Took it out, put it back together and it ran just fine.
Old March 20th, 2011, 11:33 AM   #4
rentalrider
rentalrider's Avatar
yeah I don't see how that would lock it up personally, just not run. I'd suspect something else.
Old March 20th, 2011, 11:52 AM   #5
bdd1469
bdd
bdd1469's Avatar
Never seen lock up from that either,id buy it if your competent the machine work was done correctly,tear it apart and retrieve the kids dads socket he's been missing from his toolbox.
Old March 20th, 2011, 11:56 AM   #6
chevyk10
FORD / GM
chevyk10's Avatar
Yeah I was thinking the same thing and I couldn't see how that would lock it up either. I guess I'll never know until I buy it and take it apart.
Old March 20th, 2011, 11:57 AM   #7
and post what was wrong with it when you do
Old March 20th, 2011, 12:02 PM   #8
bdd1469
bdd
bdd1469's Avatar
After thinking about this a little more im thinking why replace a 300 six with a weezin lil 302? The six makes more torque,probly the same horse power or real close.ford small blocks are turds,why do you think every fast mustang you ever see has a blower or turbo on it,or its so hyper it has no life span.id stick with the six. Just my $02.
I did have a stock oil pump drive sheer off with a hv pump, which locked up a brand new ford 302 i built when i was a kid.butt you would have to have had the motor running to do that.
Old March 20th, 2011, 12:38 PM   #9
firehawk
Live Action!
firehawk's Avatar
Right, nope. But you could put a 351 in it.
Seems most uneducated people compare the Ford 302 to a Chevy 350 or similar and downplay the ford. Compare it with the 351 and it will be much closer.
Old March 20th, 2011, 12:40 PM   #10
firehawk
Live Action!
firehawk's Avatar
No need for a HV pump and that is common if you put one in.
Old March 20th, 2011, 12:50 PM   #11
Toivo
Feel lucky?
Toivo's Avatar
was it timed properly? valves hitting pistons can cause lockups.
Old March 20th, 2011, 02:50 PM   #12
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
well its a long shot but I have seen engine backfire and run backwards. it could be that while trying to get it running it did just that. if the oiling system wasn't primed or it ran a bit longer then it should have backward the lack of oiling would have froze he bearings after they over heated.
Yetti
Old March 20th, 2011, 07:15 PM   #13
frdboy
frdboy's Avatar
Old March 20th, 2011, 09:00 PM   #14
chevyk10
FORD / GM
chevyk10's Avatar
Cause my 300 is extremely slow and this 302 is completely built up with all high proformance parts. Can't stand going 55 then bogging down to 45 every time I hit a hill.
Old April 11th, 2011, 01:46 PM   #15
Never_Evil
I would not spend money to buy and engine that is locked up just to find out whats wrong with it. Call me stupid for not throwing my money away, doesn't matter if it is hopped up with expensive parts or not. Keep your 300 and regear your axles to keep your power band where you want it and save a lot of money.
Page generated in 0.25079 seconds with 68 queries
