Sfa chevy colorado - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 5th, 2011, 06:35 PM   #41
jeepnxj96
jeepnxj96's Avatar
Originally Posted by bbaXJ View Post
It would ride and drive much better with longer, flatter links. Not sure what you mean by angle of separation? Looks like the upper and lower converge at almost the same point at the frame so it's pretty much gonna behave like a radius arm setup. I mean it doesn't look like a terrible setup or anything but I'm not quite following your logic.
Packaging on one of those trucks is a beast, with out hacking the frame all to pieces or lifting it to the moon, or completely redoing all the cross members, you are stuck with the shorter arms. For what the owner wanted to accomplish, and the type of wheeling he plans on in the near future, this set up will work.
Old May 5th, 2011, 07:08 PM   #42
Sfa_Colorado
RIDGEOFFROAD.COM
Sfa_Colorado's Avatar
U must know Chad lol
Sfa_Colorado is offline   Reply With Quote
Old May 5th, 2011, 08:51 PM   #43
BBCYJ
http://ridge-off-road.web
BBCYJ's Avatar
I had a chance to look at this truck out at Ridge, looked like a great setup to me!
BBCYJ is offline   Reply With Quote
Old May 6th, 2011, 08:40 AM   #44
2001v10
Are those custom built link arms or off the shelf items? Almost look like the link arms off a Skyjacker lift kit for 98-02 Dodge Rams.
Curious to see your build list if you have one.
2001v10 is offline   Reply With Quote
Old May 7th, 2011, 08:58 PM   #45
JeepKeys
JeepKeys's Avatar
all custom 2"...1/4 wall d.o.m. 250# coils extended un compressed @22" ...1 1/4"currie johnny joints at one end bushings at the other... overall fun build... just tough to keep lengths and angles in check without cutting the hell out of the frame and crossmember...all in all it came out great ...drives awesome ...rides great and flexes very well... a few brackets from ballistic the rest the good old fashioned way with a lotta grinding...lol...
JeepKeys is offline   Reply With Quote
Old May 8th, 2011, 12:29 AM   #46
Joxracing
Joxracing's Avatar
Question, why did you decide to use stud-type shocks than the normal, eyelet shocks?
Joxracing is offline   Reply With Quote
Old May 8th, 2011, 06:27 PM   #47
JeepKeys
JeepKeys's Avatar
no real reason other than ease of replacement and funtionality they are heavy duty monroe shocks for a yj...in this application they offer 14 plus inches of total wheel travel and the dampening of a factory style replacement shock offers a great on road ride without being too harsh ...and a bonus that every parts store has them on the shelf in case you destroy one playin' ...
Old May 8th, 2011, 06:32 PM   #48
JeepKeys
JeepKeys's Avatar
also limit straps will be added soon ..he just needed the truck before they came in ...
Old May 8th, 2011, 06:40 PM   #49
joe_jeep
welfare wheeler
joe_jeep's Avatar
looks like passenger side drop to me. so the factory transfercase is out.
what ya gonna run? divorced 205?
or is this a v8 swap using older chevy stuff?
Old May 8th, 2011, 07:07 PM   #50
JeepKeys
JeepKeys's Avatar
actually the colorados run pass drop t cases...i know... goofy l.o.l....but his case is trashed he was going to get another used one ...but im not sure what he has decided...we will have to see when we finish the build ...if we go with another stock case we have to custom build an adapter to go to a flat flange style shaft on the front because the front yoke is only available as a ball style c.v. shaft... similiar to the front shaft on newer explorers only uses 4 bolts in a goofy pattern instead of 6 bolt common pattern...one step at a time...
Old May 8th, 2011, 09:34 PM   #51
rangerluc
rangerluc's Avatar
all i hear is , is there finally a front driveshaft??
rangerluc is offline   Reply With Quote
Old May 9th, 2011, 07:24 AM   #52
JeepKeys
JeepKeys's Avatar
he took the truck to badlands this weekend and lets just say....he almost made it home...lol...he destroyed the transfer case...and dont know what else yet...hahaha...so no front shaft yet...gotta love carnage...
Old May 9th, 2011, 10:08 PM   #53
Sfa_Colorado
RIDGEOFFROAD.COM
Here y'all go oo ps I'm thinking of maybe a 208 t case
Old May 9th, 2011, 10:14 PM   #54
Sfa_Colorado
RIDGEOFFROAD.COM
This is the diff from driver side to pass side because of a bent frame
Old May 10th, 2011, 07:02 PM   #55
BLZR
Lookin' good!
BLZR is offline   Reply With Quote
Old May 10th, 2011, 07:05 PM   #56
Sfa_Colorado
RIDGEOFFROAD.COM
Old May 10th, 2011, 07:05 PM   #57
Sfa_Colorado
RIDGEOFFROAD.COM
Old January 1st, 2012, 08:44 AM   #58
Sfa_Colorado
RIDGEOFFROAD.COM
Bump for coil up date
Parts needed
Sbc 350 or 400
Th400
Dana300- need a 4:1 gear package
Front n rear Ford or newer dodge HP Dana 60 king pin or ball dont matter
40-42 Iroks tires for 17 inch bead locks
17 inch bead lock wheels
Page generated in 0.39016 seconds with 78 queries
