87-93 Diesel vs. Gas Engine Crossmembers - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 19th, 2011, 07:35 PM   #1
kkodet
kkodet's Avatar
Default 87-93 Diesel vs. Gas Engine Crossmembers
I'm cutting up a 1992 One ton 4x4 Dodge tommorow. It is a 360 Gas truck. My question is this. Is the engine crossmember the same as the engine crossmember in a 87-93 4x4 cummins truck? I've done quite a bit of net research and it looks like it is, but I could not come up with a definative answer.
The reason I ask is that I would like to modify a full crossmember from a 1987-93 Cummins truck for my suburban cummins swap. The truck I got my Cummins motor out of was a 2wd, so I couldn't use it.
Has anyone here directly replaced a gas motor with a cummins motor in a 1987-93 dodge 4x4 truck? Is it as simple as using the pad style mounts on the gasser crossmember? If so, this crossmember should work for me.
Old March 19th, 2011, 07:37 PM   #2
boggin-machine
boggin-machine's Avatar
im going to go out on a limp and say yes it is. i helped a friend swap a cummins into a gasser and it didnt need to be changed.
Old March 20th, 2011, 06:57 PM   #3
mprmn08
mprmn08's Avatar
im pretty sure it is also.
Old March 20th, 2011, 07:36 PM   #4
kkodet
kkodet's Avatar
Pulled it out today, and it does look like it will work. It is drilled for different mounts, so I assume one set of holes is for the cummins mounts.
Old March 21st, 2011, 07:29 AM   #5
Flat_Black
The Dodge Guy
Flat_Black's Avatar
they should be the same. chrysler used the 727 and a518 on the first gen cummins wich it the same as the gassers. now if your using a stick trans that could be the problem but i dont think so. the a518 is a 727 with a overdrive unit on the back so they use the same mount. pm blackout on here cade can help you with anything 1st gen cummins.
Old March 21st, 2011, 04:29 PM   #6
kkodet
kkodet's Avatar
Thanks, but the question was about the engine crossmember, not the trans crossmember.
Old March 21st, 2011, 04:34 PM   #7
Flat_Black
The Dodge Guy
Flat_Black's Avatar
lol sorry about that, it was early. yes the engine side is the same
Page generated in 0.17153 seconds with 44 queries
