D44A Shafts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 19th, 2011, 05:07 PM   #1
ingersoll113
ingersoll113's Avatar
Default D44A Shafts
Hey guys and gals... Looking for rear shafts for a 1998 Grand Cherokee D44A 5.2 litre motor. Can pick up. Not sure if WJ would worK. Anyone know?
ingersoll113 is offline   Reply With Quote
Old March 20th, 2011, 02:21 AM   #2
jeepers48
jeepers48's Avatar
I have a rear shaft from a 2004 WJ D35. (drivers side rear)I believe the shafts are the same, Both D44-a and D35's used the same disc brake backing plates and bearings.1999 thru 2004. One of the "many" jeep guru's would have to verify that. I can take a few pics of the shaft and D35 housing, if you like?
jeepers48 is offline   Reply With Quote
Old March 20th, 2011, 10:45 AM   #3
ingersoll113
Default Axle
I understand that it needs to be ZJ only. WJ bearing is pressed on shaft. And D35 will not interchange with D44. Thanks though.
Page generated in 0.22903 seconds with 32 queries
