D35 with Lock Rite lunchbox question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 18th, 2011, 12:52 PM   #1
WebToad216
WebToad216's Avatar
Default D35 with Lock Rite lunchbox question
Okay, I searched everywhere on here and nothing I found worked.
I'm sure this has been covered and covered but I can't get the C clips off the old rear shafts to replace them. The locker is completely in the way and there is not enough room to get them out with a magnet like everyone suggests. What do I have to do to get the old shafts out?
Please don't flame, I miss driving my Jeep
WebToad216 is offline   Reply With Quote
Old March 18th, 2011, 01:22 PM   #2
remove the cross pin
Old March 18th, 2011, 01:43 PM   #3
WebToad216
WebToad216's Avatar
I did. Still can't get C clips out when I push shaft in. Locker doesn't leave enough room
Old March 18th, 2011, 01:54 PM   #4
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Get another person to push the axle in. Use a pry-bar to shift the locker over enough to get the c-clip out with a magnet or a clip.
Now on the other hand, it's possible that you twisted the shaft just enough that you can't get the axle to slide in any further. You
ll have to grind the axle off at the c-clip- and yes, it does suck. Don't ask how I know this.
Old March 18th, 2011, 03:26 PM   #5
littletrucker
I'd hit that
littletrucker's Avatar
I just did this by myself with an Aussie locker, remove the pin, and you push the axle in, I don't believe it was as far in as it would go, but then you push the locker open on that side, you may have to push the axle in and out to get it lined up just right, I pointed the slot down and used a small screw driver and magnet to persuade the clip to fall out. you do have to get the little c clip cup out of the way, i just pushed in inwards. Tapping on the carrier with a small ball peen hammer (lightly-multiple times) helped line the c clip so it pointed down. Should be a piece of cake unless you have other issues going on
Old March 18th, 2011, 03:45 PM   #6
WebToad216
WebToad216's Avatar
Thanks guys. I'll let you guys know how it goes
Old March 21st, 2011, 10:06 AM   #7
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Might be a dumb question....
What year is the vehicle? (Are you sure it's a c-clip axle?)
Old March 21st, 2011, 05:56 PM   #8
don4life
don4life's Avatar
also im sure you will have to remove passenger clip first because that is the last 1 to go on/in
don4life is offline   Reply With Quote
Page generated in 0.25603 seconds with 47 queries
