Ford Trans swap 95 to97 PS - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 17th, 2011, 07:05 AM   #1
jmdzuk
jmdzuk's Avatar
Default Ford Trans swap 95 to97 PS
I have a 1995 auto trans power stroke and want to swap in a 4x4 auto trans from a 97 power stroke.
A friend questioned if they would interchange do to modle year changes from 95-97.
Jeff
I have the electrical harnesses computer ext.from the donor truck.
jmdzuk is offline   Reply With Quote
Old March 18th, 2011, 07:08 AM   #2
Tom
Because racecar
Tom's Avatar
Most of the changes done to E40D were done internally to increase durability. The 95 and 97 are similar transmissions with 97 being a more updated and more durable trans. The only thing you might have to change is the range sensor (attached to the manual lever on the side of the trans) or the solenoid pack which requires removing the pan to swap out. I don't think you'll have to swap the solenoid pack, because if I remember correctly, the year break is 94 down are the same and 95 up should be the same.
Old March 18th, 2011, 10:05 PM   #3
jmdzuk
jmdzuk's Avatar
Thank you
Jeff
Old March 19th, 2011, 09:58 PM   #4
camccardell
tiger blood
camccardell's Avatar
hey!
some 95 trans used a diffirent solenoid than the 96-up ones.
I know this because I converted my 95 ecm to a 96 obd2 and it fried it!
there is an article about it in the bauminator trans controller install manual.
It is a stand alone controller for the e4od
Old March 20th, 2011, 12:12 PM   #5
Tom
Because racecar
Tom's Avatar
Originally Posted by camccardell View Post
hey!
That may be true for a stand alone controller, but the 95-97 solenoid packs are the same and interchangeable thus not harming the ECM. 89-94 wont plug into the 95 up solenoid packs. He is going to be fine with his 97 trans because the diesels stayed relatively the same with the exception of some internal upgrades. The solenoid pack he needs to watch out for is the late 1998 up PWM solenoid packs.
Page generated in 0.41958 seconds with 38 queries
