Another caravan question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2011, 03:28 PM   #1
Marc H.
Redreck Cadillac
Marc H.'s Avatar
Default Another caravan question
Just put in a new motor, runs great. But I have no torque what so ever being delivered to the wheels. It's a 2005 with the 3.8
My question is if it has a safety switch that needs to be reset after a blown engine. I have no service manual.
Marc H. is offline   Reply With Quote
Old March 15th, 2011, 06:32 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
https://elibrary.mel.org/validate?ur...ch%3Fdb%3DCHLL
use the link to look up your service manual.
I am at a loss on the question at hand.
Yetti
Old March 15th, 2011, 08:48 PM   #3
Marc H.
Redreck Cadillac
Marc H.'s Avatar
Thanks Yetti
Old March 16th, 2011, 05:26 AM   #4
JeepInABox
In too deep
JeepInABox's Avatar
Did you add any fluid to the trans?
You must use ATF3 or ATF4.
The wrong fluid can cause slipping.
Old March 16th, 2011, 06:59 AM   #5
Marc H.
Redreck Cadillac
Marc H.'s Avatar
I didn't touch the trans when i pulled the motor. I did pull the filter last night and going to replace this morning. The fluid was still full, but there was no slipping or movement at the tires what so ever. I jacked up the van and still no movement at the wheels.
Old March 16th, 2011, 09:10 AM   #6
Marc H.
Redreck Cadillac
Marc H.'s Avatar
Talked to another trans guy and he is telling me it sounds like the pump is shot. frick....
Old March 16th, 2011, 11:16 AM   #7
JeepInABox
In too deep
JeepInABox's Avatar
did the last engine seize? or come to a abrubt stop?
Old March 16th, 2011, 09:05 PM   #8
Marc H.
Redreck Cadillac
Marc H.'s Avatar
It threw a rod out the block. I was jammed real tight. I had to break out the rest of the block to get the piston out in order to turn the main. I found a low milage trans in kalamazoo.
Old March 17th, 2011, 05:28 AM   #9
JeepInABox
In too deep
JeepInABox's Avatar
The sudden stop may have sheared the input shaft in the trans.
It would be easier to just swap the trans.
Old March 17th, 2011, 05:56 PM   #10
Marc H.
Redreck Cadillac
Marc H.'s Avatar
I went and picked one up today. Now I gotta figure out if I can get it out the bottom easy. Hoping to support the engine and drop the trans.
Old March 18th, 2011, 08:55 AM   #11
Tom
Because racecar
Tom's Avatar
The trans will come out of the bottom easily. You most likely broke the pump gears installing the motor. Why didn't you buy a $100 pump and install it rather than buying a whole trans?
Old March 18th, 2011, 09:03 AM   #12
Shotgun
I only wheel with boats.
Shotgun's Avatar
If its anything like the one I did a few weeks back it will come out the drivers wheel well.
http://forum.chryslerminivan.net/
Great site!
Old March 18th, 2011, 09:53 AM   #13
Marc H.
Redreck Cadillac
Marc H.'s Avatar
I thought about replacing the pump but if anything else got messed up then I would be in the same boat as now. I pick up a trans in K-zoo yesterday with 50k on it for a few hundred bucks. The van itself has 127k on it. Figured I was better off with a fresher one.
Old March 20th, 2011, 09:12 PM   #14
Marc H.
Redreck Cadillac
Marc H.'s Avatar
Thanks guys, the engine did fit through the top just had to remove the water pump. The trans did drop easy out the bottom, minus a bolt in the rear trans mount being cross threaded from the factory or from prior service being done. It does run and drive good now. So again thanks for the input.
Page generated in 0.27896 seconds with 65 queries
