8.8 swap question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2011, 01:03 PM   #1
upchuck
upchuck's Avatar
Default 8.8 swap question
Weather's warming and no excuses, so it's getting time to finally do my swap.
Does anybody run into issues with the pig hitting the gas tank in a TJ?
Seems with the cover on, it looks to go at least another 2" back from the centerline of the axle.
upchuck is offline   Reply With Quote
Old March 15th, 2011, 05:16 PM   #2
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I think with it in stock location you should be fine.
Old March 15th, 2011, 06:20 PM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
It's not uncommon for it to rub just slightly, depending on angle and lift height. You can either "clearance" the diff cover or the tank skid.
Old March 15th, 2011, 06:24 PM   #4
upchuck
upchuck's Avatar
A stock LCA is 16" and I'm out to 161/2 with a 4" RC lift that actually is higher.
By "clearance" I'm guessing you mean the BFH route
Old March 15th, 2011, 06:26 PM   #5
Jeeperz Creeperz
GL 4x4 Vendors
Yes, thus the quotes
I'd try it first and see if it rubs. If not, you're set.
Old March 15th, 2011, 06:57 PM   #6
upchuck
upchuck's Avatar
I'm trying not to buy new lowers, but with my TT and lift I'm at 20 deg on the pinion so...
Page generated in 0.24563 seconds with 41 queries
