compare the 8.25 to the 8.8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2011, 01:47 AM   #1
jeepguy74
jeepguy74's Avatar
Default compare the 8.25 to the 8.8
just curious as to the differance in strength of the 8.25 out of a cherokee and the 8.8 from a explorer.....
just curious as i have a chance to get a 8.25 and thought that i may go that rout insted of the 8.8 ki was considering...
i see alot of threads on swaping in a 8.8 but none on going with a 8.25 since they are available from cherokee....
what are yor thoughts and info??
Old March 14th, 2011, 02:06 AM   #2
Shotgun
I only wheel with boats.
Shotgun's Avatar
8.8 has bigger shafts and more aftermarket support.
Old March 14th, 2011, 05:16 AM   #3
MiNi Beast
MiNi Beast's Avatar
well depends which 8.25 kinda, you have the older 27 spline and then the newer 29 spline 8.25 vs the explorer 31 spline 95+ with disc brakes from factory. and the 8.8 stock can handle up to 37" tires, and then can be upgraded to 33 spline yet after that. I'm a big fan of the 8.8 but it really depends on style of how you drive and what your overall goals are, and as well as what type of a budget you have set aside for the axle swap.
Check this out for some axle comparisons. 8.25 vs 8.8
Old March 14th, 2011, 05:16 AM   #4
MiNi Beast
MiNi Beast's Avatar
fyi, "compare"
Old March 15th, 2011, 02:17 AM   #5
jeepguy74
jeepguy74's Avatar
Originally Posted by MiNi Beast View Post
fyi, "compare"
brain fart...fixed now
Page generated in 0.16122 seconds with 38 queries
