D60 or 70? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 4th, 2006, 01:09 PM   #1
Leanz
Full taste of tender
Leanz's Avatar
Default D60 or 70?
http://mav.wastegate.net/tech/dana60-70.html
looks like a d70 according to that website... it was sold to me as a d60? maybe im just retarded and there are some d60s that have d70 housings!? tell me what you think
and the ring gear says 70 dana... maybe that has no correlation though. i ran the #'s off the ring gear and nothing came up... i need the #s from the housing, but its really hard to get to right now
Leanz is offline   Reply With Quote
Old September 4th, 2006, 01:11 PM   #2
BMFmike
meh.
BMFmike's Avatar
70!!!!!11!!1
Old September 4th, 2006, 01:14 PM   #3
clarkstoncracker
lol
clarkstoncracker's Avatar
when I was shopping for axles, I looked into a dana 70.. The only difference is the ring gear is bigger then the dana 60. I think it was less then an inch of difference.
Hopeflly you have the dana 70HD... There are 70's with smaller junk in them, I don't remember their code.
Old September 4th, 2006, 01:15 PM   #4
Leanz
Leanz's Avatar
yes 9.75 or 10.5
Old September 4th, 2006, 01:30 PM   #5
TJrockdogg
Living on the Edge
TJrockdogg's Avatar
that thing looks like it has been wet for some time, I just did the 10 bolt in my van with 250K on it and didn't even come close to the rust in that.
TJrockdogg is offline   Reply With Quote
Old September 4th, 2006, 01:47 PM   #6
Leanz
Leanz's Avatar
well that will happen to any axle that sits for a while with no fluid, the rust dosnt matter.... i just want to know d70 or not.
Old September 4th, 2006, 01:49 PM   #7
BMFmike
meh.
BMFmike's Avatar
Originally Posted by BMFmike
70!!!!!11!!1
x2
Old September 4th, 2006, 01:54 PM   #8
DetR6oit
Thats not true. Basicly everything on the 70 is bigger, axle tube size, axle tube thickness, axle shaft size, and along with ring gear.
The only differance between most of the Dana 70s is the housing shape and strength. There are some that have differences in the carrier that can make getting lockers for them harder I believe.
Does it have shafts? what spline are they?
DetR6oit is offline   Reply With Quote
Old September 4th, 2006, 01:55 PM   #9
BMFmike
meh.
BMFmike's Avatar
Dude, thats way to easy to count the splines.
Old September 4th, 2006, 02:05 PM   #10
Leanz
Leanz's Avatar
30 spline hmmmmm.... d60 shafts? d70 housing?
Old September 4th, 2006, 02:07 PM   #11
BMFmike
meh.
BMFmike's Avatar
60!!!!!11!!1
Told you so
Old September 4th, 2006, 02:31 PM   #12
DetR6oit
Originally Posted by Leanz
I just noticed that guy stole my old pics I took, and put up on MJ for the axle identification thing.
Old September 4th, 2006, 02:35 PM   #13
DetR6oit
Does't the number on the lower right hand webbing say 60??? Thats about as obvious as it gets. I don't see anything that makes me think its a 70. The number on the ring gear means nothing. That number is the manufacture date I believe
Old September 4th, 2006, 03:32 PM   #14
Leanz
Leanz's Avatar
it says 80. and the left side of the pig, top and bottom both show (according to those pics) its a 70, but the right side shows its a 60? ahhh who cares, looking at the brakes makes me think its a 60 too ... bummer
Old September 4th, 2006, 03:59 PM   #15
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Looks like a 60. 30 splines shafts are 60 Check the BOM if you really want to know everything about it.
Old September 4th, 2006, 10:17 PM   #16
biohazardbill
The Biohazards
biohazardbill's Avatar
I have a D70 in the garage if you wanna look at it to compare.
biohazardbill is offline   Reply With Quote
Old September 4th, 2006, 10:25 PM   #17
Looks like a 70... but just get a ruler and measure the ring gear.
Some people don't know the difference, since they take the same cover...
Old September 4th, 2006, 11:06 PM   #18
Cooter
Cooter's Avatar
Here is a 70
Look at the extra beef in the housing (sorry, Billavista has the picture of it upside down)
D70s were much more common in duallies than SRW applications.
Here is a better one- look at the location of the pinion. (Again, upside down- I would rehost and flip these pix, but because I am on dial up, you wouldn't get this post 'till next week some time)
Yours
(I just stole you picture and flipped and rehosted it because it was easier)
Also, check where the extra casting material extends past the cover. (upside down, and already partially shaved) Also see how much less room there is between the lower (now upper) bolt holes and the inside of the housing.
They commonly have lots of beef in the center section.
Old September 6th, 2006, 08:58 AM   #19
PavementPounder
PavementPounder's Avatar
D60 left, D70 right. Note the extra webbing on the driver's side (big rib like a HP front has) and significantly different contours all around the top half of the case compared to the D60. Notice also the obvious overall difference in case depth and tube diameter. The centersection/axle model number will be the one on the passenger lower web, which you said was 60.
The one you see on the right is my CJ-8 axle, which is a 2-pc carrier Dodge. I haven't been told that there was anything odd about it when we were looking into options during the build, but that was probably because we were looking up Detroits. I have one of the mid-80's big-bearing Chevy D70's as well, but have not opened it yet. I don't have any before/after pics of the Ram's D70. Here's a picture of one of the 2-pc carriers:
Old September 6th, 2006, 09:54 AM   #20
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
It is a 60... NO 70's came with 30 spline axles... There are many versions of the 70. The pinions are offset differently between application. Like mentioned above some are harder to find lockers for then the others due to carrier design. The most common is the dana 70 "U". There is also a dana 70 that only comes in a 3.73 and that is it no other gear will fit in it.
Page generated in 0.29266 seconds with 83 queries
