SOLD - Ford big block 429 / 460 performance and 4x4 truck performance parts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 13th, 2011, 01:25 PM   #1
broke33
Default SOLD - Ford big block 429 / 460 performance and 4x4 truck performance parts
Part Location: in Brighton.
Shipping options: Pickup is preferred but shipping can be arranged at buyers expense.
Payment mathods: cash and paypal are the best. I will accept a postal money order but it will need to clear the bank before it ships.
These are parts left over from a 1991 Ford 4x4 project I did a few years back and now Im just cleaning out the basement. Almost everything below is still in the original unopened packaging. You can call me directly to talk at 810-923-4137 or email me. Calling me is the best way to get "dibs" as I may not be watching the website but once or twice a day due to work load.
Items I may be interested for trading are 429 460 Heads, stroker cranks, H-beam or better rods and pistons, RPM or torquer 2 manifold, 850 CFM or bigger 4150 style carb or 4-bolt blocks.
The parts are for a 429 or 460 big block but some of these parts may work on other engines and the part numbers are included so you can cross reference):
Crane steel distributer gear(52971-1) was told I needed it ofr my roller cam brand new = $60
Lunati cam (41605) with 14 lifters (cant find the other 2. This is used but very little. I have the cam card. 0.559IN/0.572EX, 237IN/247EX @ 0.050 duration = $110
Hughs torque converter (35-30HD) C6, 1.848 pilot hole, 10" 3000 Stall, brand new = $300
Transgo shift kit stage 1 and 2 (67-1&2) for C6. Brand new = $30
Power steering pump with plastic reservior. Fits 78 - 96 Bronco, F150 F250 F350 78 - 79 Cougar and LTD2 79 - 80 Thunderbird. Brand new = $75.00
Skyjacker front extended stainless brake lines for 4 and 6 inch lift for F250 and F350 (FBL 91) Brand new = $80
Skyjacker rear extended stainless brake lines for 4 and 6 inch lift for F250 and F350 (RBL 90) Brand new = $40
Vacuum reservoir with gauge (SUM-G1464)Brand new = $25
Brake master cylinder with tank from 1994 4x4 F350 dually. Has the large diameter bore piston = $35.00
Brake power booster (54-74400) 1990 - 1997 F250 and F350. Brand new = $50
broke33 is offline
Old March 13th, 2011, 09:13 PM   #2
broke33
Oil pan sold.
MSD distributor pending
broke33 is offline
Old March 14th, 2011, 06:20 PM   #3
broke33
REsponded to PM's
broke33 is offline
Old March 14th, 2011, 09:56 PM   #4
joshcorey56
if you have a solid roller cam you CANT use a iron gear. gota use the bronze
joshcorey56 is offline
Old March 15th, 2011, 07:30 AM   #5
broke33
Im not going to start a debate here but this gear is intended for use witht he roller cams that use the induction hardened gear on the cam. This is recomended by Crane (and other very good engine builders) for solid rollers in a street application.
If you are concerned about using this for your application I suggest you contact Crane directly and they will tell you if it is a good match. There are some exotic material cams (billet for example) with special steel gears pressed on that this would probably not work on.
broke33 is offline
Old March 15th, 2011, 08:30 AM   #6
Cool parts peddler
Ironman Offroad's Avatar
PM sent
Ironman Offroad is offline
Old March 15th, 2011, 07:45 PM   #7
broke33
PM sent
Responded to PM
broke33 is offline
Old March 16th, 2011, 10:22 PM   #8
broke33
3 inch X pipe is sold. Listing is updated. Make offers
broke33 is offline
Old March 19th, 2011, 10:13 AM   #9
broke33
Oil accummulator is sold. Make me some offers. This stuff is new
broke33 is offline
Old March 21st, 2011, 06:25 PM   #10
broke33
updated to show more things sold
broke33 is offline
Old March 23rd, 2011, 05:29 AM   #11
broke33
Sold all the ignition componentry, intake and trans mounts.
broke33 is offline
Page generated in 0.20133 seconds with 56 queries
