78 351m cam ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2011, 05:25 PM   #1
codyjames
codyjames's Avatar
Default 78 351m cam ?
putting my engine back together its .030 over flat top 351m i have a edelbrock preformer intake and a 650 holley carb its going back into my bronco mainly used as a mud truck i am curious if anyone has any imput on what cam i should get for it i know an rv cam would be good but i was hoping someone would have a spec that they know works well for this application
codyjames is offline   Reply With Quote
Old March 9th, 2011, 05:28 PM   #2
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
I've had 2 Comp Cams extreme 4x4's in my blazer. You need some more info on the vehicle first! Stock stroke? Tranny, gears, rpm range, what heads, valve size, dual plane or single plane intake and so on
Old April 2nd, 2011, 07:36 PM   #3
BOGDOG
BOGDOG's Avatar
Last time I built one of those motors I used a Sig Erson TQ20 cam.It worked great No idea if still available. You need to do some research like previous poster said. Intended usage and gears,tire size, trans, etc all play a part in selecting a cam.
Page generated in 0.13766 seconds with 32 queries
