Superduty Door switch? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 8th, 2011, 06:28 PM   #1
kickstand
circling the drain
kickstand's Avatar
Default Superduty Door switch?
Where the hell is it?
Dome light won't turn off, door ajar light on dash stays lit. It's dark and tough to find, no luck in the driveway....
Old March 8th, 2011, 06:31 PM   #2
blade262us
blade262us's Avatar
Default Door ajar
Take a can of WD40 and spray in the door latch all around inside it then open and close the door a bunch of times then spray some more . Mine used to do that too then after getting it to break free with the WD I sprayed white lithium in there and havent had a problem with it for a couple yrs .
blade262us is offline   Reply With Quote
Old March 8th, 2011, 06:31 PM   #3
s.hembree
s.hembree's Avatar
It's in the latch if I recall correctly.
Old March 8th, 2011, 08:19 PM   #4
kickstand
circling the drain
kickstand's Avatar
I found that on google as well.
Sprayed it, haven't been back outside, but at least I know the culprit.
Old March 8th, 2011, 09:18 PM   #5
frdboy
frdboy's Avatar
Mounts in the bottom of the door latch assy, gets gummed up and sticks. Not too bad to replace if WD40 dosen't work.
Old March 9th, 2011, 07:31 AM   #6
kickstand
circling the drain
kickstand's Avatar
I'll report back tonight, hopefully wd40 did the trick.
Old March 9th, 2011, 07:40 AM   #7
Quiefinator
go'til itsounds expensive
It has worked for me many a time. I would also check weatherstripping, seal, bumpstops etc. Especially with as much ice/ snow we've had.
Page generated in 0.31609 seconds with 44 queries
