warn rear hub conversion?????? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 8th, 2011, 11:08 AM   #1
tctrojan17
Sexy and I know it.
tctrojan17's Avatar
Default warn rear hub conversion??????
I have a 10 bolt with a warn 60 hub conversion. It has lockouts in the rear and from my understanding what is equivalent to custom 6o shafts that come with it. I have been trying to find info on it but have been coming up empty handed.
Anyone have any knowledge on these axles and also what it may be worth?
Any info would be appreciated. Thanks Jeff
tctrojan17 is offline   Reply With Quote
Old March 8th, 2011, 11:22 AM   #2
fishyoo7
fishyoo7's Avatar
So you have a Warn Full Float kit for a 10 bolt rear axle. What was the axle under?
fishyoo7 is offline   Reply With Quote
Old March 8th, 2011, 11:54 AM   #3
Some info here:
http://www.pirate4x4.com/tech/billav...37;20Axles.pdf
They should be 4340 alloys, strength is probably close to OEM D70/14b. Obviously your ring and pinion are still the same strength. The hubs are 30 splne hubs, (or flanges, based on your kit)...Warn makes 30 splien hubs for both dana 44s and Dana 60s..
Count the number of splines on the outside of the hub body (inside for the axle will be 30 splines either way) .... 48 splines = d44, 55 splines = d60...
Old March 8th, 2011, 04:03 PM   #4
tctrojan17
Sexy and I know it.
tctrojan17's Avatar
The axle is currently under a 94 full size blazer. Being removed though for rockwells.
Some info here:
http://www.pirate4x4.com/tech/billav...rn%20Axles.pdf
Thanks i appreciate it, i should of thought to go check pirate.
Page generated in 0.21406 seconds with 35 queries
