hydro steering... got more. 10/19/2012 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 7th, 2011, 09:27 AM   #1
hit&run
hit&run's Avatar
Default hydro steering... got more. 10/19/2012
i have some hydro steering set up's for sale. they come with one orbital valve and one steering cylinder. all you will need is new hoses. these are located in jerome mi. 49249.
price is $125.00 per set up.
And $175.00 shipped.
hit&run is offline   Reply With Quote
Old March 7th, 2011, 09:28 AM   #2
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Is this full hydro or hydro assist?
Do you have any pictures of a setup?
Old March 7th, 2011, 09:32 AM   #3
hit&run
hit&run's Avatar
this is full hydro and sorry i have no pics as of now. two of them are charr lyn orbital valves.
Old March 7th, 2011, 09:37 AM   #4
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I'd be very interested if you could get a picture of it.
Is this a double ended ram? Or a caged ram?
Old March 7th, 2011, 09:39 AM   #5
hit&run
hit&run's Avatar
single ended ram. these are take off's from a combine. all you will need is new hoses.
Old March 7th, 2011, 09:49 AM   #6
alboy79
Where's your loyalty lie?
alboy79's Avatar
Location: Comstock Park, Michigan or 49321 for shipping
What's the specs on the orbital and the size of the cylinder? All important info when trying to sell hydro parts...
alboy79 is offline   Reply With Quote
Old March 7th, 2011, 09:53 AM   #7
hit&run
hit&run's Avatar
not really, i've sold over 40 set's with the same ad as this. they are off combines and are 4 port valves with single ended ram's.
Old March 7th, 2011, 10:07 AM   #8
schanxj
schanxj's Avatar
Does this just run off the stock power steering pump/reservoir?
schanxj is offline   Reply With Quote
Old March 7th, 2011, 10:09 AM   #9
hit&run
hit&run's Avatar
yes they do.
Old March 7th, 2011, 10:29 AM   #10
orionn
orionn's Avatar
How many turns lock to lock on the orbital valve? (aproximatly)
are the orbitals self pumping in case the engine dies (can you still make the ram move without the pump running)
orionn is offline   Reply With Quote
Old March 7th, 2011, 10:34 AM   #11
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
yes actually it is, what size cylinder and what displacement valve
Old March 7th, 2011, 10:37 AM   #12
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
40 sets cant be wrong..
Old March 7th, 2011, 10:49 AM   #13
alboy79
alboy79's Avatar
That's what I was thinking....
Old March 7th, 2011, 11:12 AM   #14
hit&run
hit&run's Avatar
sorry but i'm not sure how many turn's to get lock. the ones i've used will still make the cylinder work without the pump running, they turn hard but do work.
Old March 7th, 2011, 06:45 PM   #15
michigan maniac
michigan maniac's Avatar
how long is the throw of the ram?
Old March 7th, 2011, 07:08 PM   #16
hit&run
hit&run's Avatar
i will have to measure a couple and let everyone know. i have a pic of a orbital but none of the cylinders.
Old March 7th, 2011, 07:31 PM   #17
hit&run
hit&run's Avatar
as of now all of these are sold or spoke for. i'm working on getting more i will let everyone know asap.
Old March 17th, 2011, 05:40 PM   #18
hit&run
hit&run's Avatar
i will have more of these tomorrow but they are a different style. they have a two port orbital that runs to a porportioning valve then down to the steering cylinder. cylinders i've measured have been 8 inch stroke. pm me if you are interested, first come first serve. thank's for looking.
Old March 17th, 2011, 06:05 PM   #19
GearDrive
A little slow
GearDrive's Avatar
I have a setup like this on my rig and the turns lock to lock are different left to right with a single ended ram. It takes more oil to extend the cylinder than to retract. The number of turns is simular to a normal truck.
I can turn the wheels without the engine running, but it will pull air into the system.
The system I bought also had 1 ton tie rod ends for a simple install.
GearDrive is offline   Reply With Quote
Old March 18th, 2011, 09:21 PM   #20
hit&run
hit&run's Avatar
i've got four left.
Page generated in 0.32845 seconds with 83 queries
