disc brake question on ford 8.8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 6th, 2011, 07:46 PM   #1
TJ SKWIG
Professional Dumbass
TJ SKWIG's Avatar
Default disc brake question on ford 8.8
is it ok to spin the caliper bracket 180 degrees so that the driver side caliper is towards the front of the vehicle? and leave the passenger side caliper in the stock location? didnt know if there was an issue of not having them both towards the back of the axle or not.. the reason for wanting to do this is there isnt enough clearance for my staggered shocks to mount to the bottom spring plate in the stock location.. drivers side shock goes to the back of the axle, passenger shock to the front of the axle.. please discuss pro's and cons of this modification,, thanks!
TJ SKWIG is offline   Reply With Quote
Old March 6th, 2011, 08:51 PM   #2
Jeeptj1999
Jeeptj1999's Avatar
Will be harder to bleed, but i think you might be able to swap them side for side to fix this.
Jeeptj1999 is offline   Reply With Quote
Old March 6th, 2011, 10:47 PM   #3
mtheaded
yes, caliper position on the axle has very little overall effect on braking. some vehicles have the rear calipers on the front side of the rotors, some have them on the rear side...
mtheaded is offline   Reply With Quote
Old March 6th, 2011, 11:31 PM   #4
yyj87
yyj87's Avatar
I believe the bleed screw will be much lower after you move it, this will make bleeding much more enjoyable. No effect on braking.
Shawn
yyj87 is offline   Reply With Quote
Old March 7th, 2011, 10:55 AM   #5
BIGBEN
All out Idiot
BIGBEN's Avatar
can you mount a passenger side caliper in the drivers bracket?
that way when you rotate the bracket forward the bleed screw will be back on top of the caliper.
BIGBEN is offline   Reply With Quote
Old March 7th, 2011, 11:13 AM   #6
Have you checked the brakets for anything else that'd be an issue if it was rotated? I can't remember, I have a box of 8.8 explorer disc stuff going onto my 9", isn't the bracket integrated into the backing plate?
Anyway, the other option you have, which is a pain but possible, is remove the caliper, and secure it somehow so the bleeder is upright (may need to place a tight fitting block of wood or steel inside the pads, depending on your bleeding method), and bleed it, then remount it, assuming you have enough flex line on there to do this.
Old March 7th, 2011, 11:47 PM   #7
TJ SKWIG
TJ SKWIG's Avatar
this option did come to mind but i may just try to drill and tap the other side of the caliper for a new bleeder.. looks like the only difference in the calipers is the location of the bleeder. seems like it should work.. dont want to buy a new caliper if i dont need to..
Old March 7th, 2011, 11:52 PM   #8
TJ SKWIG
TJ SKWIG's Avatar
the only other thing that looks like it would be an issue is the parking brake.. but i dont plan on using that.. i also thought of using the old rotor with the caliper unmounted to bleed it.. then remount it.. id hate to have to do that everytime i want/ need to bleed them though.. thinking ill tap the other side of the caliper for a bleeder..? not sure if i can though??
Page generated in 0.34493 seconds with 47 queries
