***SOLD***Np435 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 6th, 2011, 06:40 AM   #1
insaneoffroader
insaneoffroader's Avatar
Default ***SOLD***Np435
Np 435 w/460 bellhousing. $100
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline
Old March 27th, 2011, 10:16 PM   #2
speedfixx autofab
pyro
speedfixx autofab's Avatar
Would you take $200 for the :trans, bellhousing, flywheel,clutch and pressure plate?
speedfixx autofab is offline
Old May 13th, 2011, 09:29 PM   #3
Jonesey
Jonesey's Avatar
Still have this?
Jonesey is offline
Old September 12th, 2011, 04:14 AM   #4
velcro7279
Would you separate the trans and bellhousing?
velcro7279 is offline
Old February 14th, 2012, 07:53 PM   #5
Jeepin_J
Jeepin_J's Avatar
Is this still for sale
Jeepin_J is offline
Old February 19th, 2012, 08:56 AM   #6
370
370's Avatar
does this have the 7.5" input shaft?
370 is offline
Old February 25th, 2012, 05:58 AM   #7
insaneoffroader
Ill get you a measurement as soon as poss.
Old March 4th, 2012, 08:07 AM   #8
370
370's Avatar
370 is offline
Old March 4th, 2012, 01:00 PM   #9
insaneoffroader
depending on where you measure from its 5 7/8" - 6 1/2".
Old March 4th, 2012, 04:27 PM   #10
370
370's Avatar
ok.. won't work for a swap behind a 2.5 then. thanks anyway
370 is offline
Old May 2nd, 2012, 05:27 AM   #11
Trail Mule
Trail Mule's Avatar
Where are you located?
Trail Mule is offline
Old November 3rd, 2012, 09:33 AM   #12
370
370's Avatar
is it from a 4x4? open to offers?
370 is offline
Old November 4th, 2012, 03:24 PM   #13
insaneoffroader
yes its 4x4. send your offer in Pm, all I can say is no.
Old January 12th, 2013, 04:20 AM   #14
hillbillyrockstar
Country folks living LOUD
hillbillyrockstar's Avatar
Location: from St. Clair County, working in Baltimore MD for a while
Is the trans still available?
hillbillyrockstar is offline
Old January 12th, 2013, 11:42 PM   #15
hillbillyrockstar
Do you happen to know, if the trans you have will bolt up to a bellhousing for a small block ford? (300, 302, 351) ??
Also, do you have the flywheel, clutch, clutch fork and slave cylinder?
Old January 13th, 2013, 07:36 AM   #16
insaneoffroader
Yes it will bolt up to the smallblock bell housing of the same vintage.
The flywheel, clutch, clutch fork I have is for a 460, for sale in another thread. This year of transmission did not use a slave cylinder.
Old February 24th, 2013, 08:03 AM   #17
PINKY
PINKY's Avatar
How much for a complete trans with everything needed to run
PINKY is offline
Old February 24th, 2013, 03:16 PM   #18
insaneoffroader
This is a complete trans. Not sure what you mean "everything needed to run".
Old February 24th, 2013, 05:57 PM   #19
PINKY
PINKY's Avatar
Slave/throwout clutch pressure plate and trans
PINKY is offline
Old June 15th, 2013, 09:12 AM   #20
PINKY
PINKY's Avatar
How far are you from Toledo Ohio
PINKY is offline
Page generated in 0.48502 seconds with 83 queries
