318 jeep xj project homebrew - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 15th, 2011, 10:30 PM   #41
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
took it to sticks of romeo bog 9-10-11 to give it a test run. all in all it did a good job the 33 werent much of a match for all the trucks on tractor tires but i did have fun and beat the jeep good. i did find out exhaust on the drivers side is to low my axle truss smashed the pipe. besides that all went well. i did relize i need bigger tires and more hp though lol. i am happy with the 318 and cant wait for the day i can drop the 360 thats 30 over in my garage in the jeep. but that is a later project need lift first.
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old October 15th, 2011, 10:10 PM   #42
CHEROKEEMUDMAN01
mellow yellow
well carb is all tuned up and she is running like a champ. now starts the long arm lift and new steering system
Old October 15th, 2011, 10:17 PM   #43
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Good to hear!
Supercharged yj
Old October 18th, 2011, 08:36 PM   #44
CHEROKEEMUDMAN01
mellow yellow
new mod to jeep finally put GL4x4 stickers on both side of jeep. only been in the glovebox for about 6 months lol.
Old December 2nd, 2011, 07:13 AM   #45
Blazin40s
That last mod ruined it lol....the sticker I mean lmfao.
Blazin40s is offline   Reply With Quote
Old February 1st, 2012, 08:12 PM   #46
CHEROKEEMUDMAN01
mellow yellow
well got lift in went with a 8.5 rustys kit been meaning to post pics. ordered my lca brackets from barns 4x4 and not i can start to remake my crossmember. fun fun
Old February 5th, 2012, 08:28 AM   #47
CHEROKEEMUDMAN01
mellow yellow
jeep went under the knife again yesterday pulled off the front axle and started setting up my long arm setup so i can make a new crossmember.
Old February 6th, 2012, 09:24 PM   #48
CHEROKEEMUDMAN01
mellow yellow
cut my crossmember open and droped my lca brackets as much as i could and still get a socket on bolt to tighten them. what anyones thoughs on how strong this setup will be.
jeep sitting at ride height the jackstands in front are 1/8" from actually touching bumper. i now have 36" from the bottom of bumper to ground and cant wait to get rear done.
Old February 11th, 2012, 12:18 AM   #49
CHEROKEEMUDMAN01
mellow yellow
well jeep project took a step backwards. i was setting up the lca and didnt relize that they were binding up on the lca brackets. turns out my lca brackets are both slitly aimed in towards center of jeep. when i ordered my truss kit 2 years ago t&t customs must have sent my the wrong brackets instead of straight brackets. so now i have to dissamble the axle grind off the lca mounts and start fresh. blows big time
Old February 11th, 2012, 06:46 AM   #50
Rob the plumber
That is the sucky.
Old July 31st, 2012, 08:19 PM   #51
CHEROKEEMUDMAN01
mellow yellow
here is the finished pics. taken along time to get done as per usually life got in the way but its alive again. tell me what you guys think.
tire is 31" off ground when rear started to lift off(springs are new with no miles so im shure it will get a little more).
Old July 31st, 2012, 08:42 PM   #52
Asher
Jack stand wheeler
Asher's Avatar
Always a pain doing things twice been there done that. Jeep looks good however the stock cross member is going to twist up and fail sooner rather than later handling the stress of those links mounted to it. I'd look into building a stronger cross member. Always liked that color of Cherokee.
Asher is offline   Reply With Quote
Old July 31st, 2012, 10:09 PM   #53
CHEROKEEMUDMAN01
mellow yellow
crossmember isnt stock. it is a 2x6 1/8 wall that i made and put frame plates to side also. i hope it holds cause that could really suck.
Old August 1st, 2012, 08:53 AM   #54
Asher
Jack stand wheeler
Asher's Avatar
Went back and found the pics of the cross member, I missed those, thought from your description you just opened up the stock cross member and added the mounts to it.
Old August 1st, 2012, 02:35 PM   #55
CHEROKEEMUDMAN01
mellow yellow
i understand i try to overkill everything cause i hate to redo stuff over and over.
Old August 1st, 2012, 02:54 PM   #56
curbdog17
Mini Van
curbdog17's Avatar
Looks good
Old October 22nd, 2012, 10:42 AM   #57
Modestmar00Xj
Show me the trails!
Modestmar00Xj's Avatar
Send a message via AIM to Modestmar00Xj Send a message via Skype™ to Modestmar00Xj
Dude! Yes! Your jeep looks great man!
Modestmar00Xj is offline   Reply With Quote
Old December 16th, 2012, 03:04 PM   #58
CHEROKEEMUDMAN01
mellow yellow
havent been doing much to jeep lately but did get out there and get some work done on it today. i have been meaning to make up a set of rock sliders and fix my prob with carb drawing in all hot air from motor bay. here is some pics what u guys think
Old December 16th, 2012, 04:11 PM   #59
1997XJ
1997XJ's Avatar
Looks sweet
1997XJ is offline   Reply With Quote
Page generated in 0.30911 seconds with 80 queries
