318 jeep xj project homebrew - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2011, 11:06 PM   #1
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
Default 318 jeep xj project homebrew
well figured i would start a build thread. here is the link to see the start of this project. http://www.greatlakes4x4.com/showthr...=191991&page=2
since the last post i have worked on getting the inside of jeep wraped up. i made my own custom set of gauges using the stock jeep gauge location. installed a tach and a b&m megashifter. also made up brackets to relocate the powersteering pump up higher since on the vans/ pu and rc's the pump is down low because the gearbox is on outside of frame rail. today i started to part of the project i have been looking foward to, building a hood scoop. keep in mind i am not a body guy and have a small set of skills so go easy on me but i am happy with the results so far, what you guys think.
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old March 5th, 2011, 11:12 PM   #2
MiNi Beast
MiNi Beast's Avatar
Looks good, nothing a little body filler can't fix.
Old March 5th, 2011, 11:25 PM   #3
CHEROKEEMUDMAN01
mellow yellow
yah got a friend who is good at body work and is going to give me so pointers tomorrow. i still have a little metal dollying to do but ran out of steam.
Old March 6th, 2011, 01:57 PM   #4
pistol pete
I do vinyl stickers
pistol pete's Avatar
i like it , looks good
pistol pete is offline   Reply With Quote
Old March 6th, 2011, 08:03 PM   #5
CHEROKEEMUDMAN01
mellow yellow
well got hood cut out today and straightened up the scoop and welded it in. then did a thin coat of body filler and hopefully by nextweekend will have it painted.
Old April 3rd, 2011, 08:41 AM   #6
CHEROKEEMUDMAN01
mellow yellow
well been working on it alot the last couple of weeks. i got wire harness all done and pulled trans and sent it off to my friends shop to get rebuilt. i made up the powersteering pump relocation brackets and alt brackets. also made a box for fuel cell and will have it mounted today. pulled motor back out and painted motor bay. here is some pics
Old April 18th, 2011, 04:46 PM   #7
CHEROKEEMUDMAN01
mellow yellow
well got the fuel cell in and here is some pics. i will be making a plate for the bolts on the inside floor and after exhaust is ran i will make brackets to tie the fuel cell to unibody instead of only floor.
Old April 18th, 2011, 04:47 PM   #8
CHEROKEEMUDMAN01
mellow yellow
finally got some time to work on motor. installed cam and duel roller timing chain on. changed out valve seals in heads and put a high volume oil pump in. took some time to clean the motor and paint it. headers turned out really good.
Old April 20th, 2011, 08:22 PM   #9
CHEROKEEMUDMAN01
mellow yellow
well got some work done today. tried to put motor in but the nice vent i put in the trans out through the top of trans bell now hits the trans tunnel. hopefully sat i can cut a peice out of tunnel and reweld it back in for some extra room.
Old April 24th, 2011, 07:53 PM   #10
CHEROKEEMUDMAN01
mellow yellow
worked on the jeep alot this weekend. got the hood scoop painted and ready for clear coat. put the trans on the motor and put them back into jeep for last time. ran the rest of wire harness now i have to make a loom. put hearers on and going to get some prices on getting the exhaust done hopefully in the next two weeks. here is some pic. what you guys think so far?
Old April 30th, 2011, 03:41 PM   #11
CHEROKEEMUDMAN01
mellow yellow
just got back from junk yard. i cut a radiator crossmember from a 96 grand cherokee. it looks like the unibody rails are the same width so i am hoping to be able to run the taller grand cherokee radiator in the xj. see if this works if not then i will be having a 2 core made up with the v8 hose inlets in right place.
Old April 30th, 2011, 06:47 PM   #12
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Subscribed. Looking great!
Craig
Old May 1st, 2011, 07:20 AM   #13
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
Subscribed!
bbrancheau is offline   Reply With Quote
Old May 1st, 2011, 07:36 PM   #14
CHEROKEEMUDMAN01
mellow yellow
today i finished the wireharness, ran the netural safty switch, and tried to make wires in engine bay look as nice as possible. i also put seats back in and installed the new b&m mega shifter. i will be getting exhaust put on in the nwxt couple days then try to fire it up and break in cam. also raised the transmission crossmember up about an inch for more clearance and got the motor setting at a better angle. now im just down to unibody stiffiners,fuel lines and trans lines and figure out radiator. then she will be alive, here is some new pics of progress
Old May 5th, 2011, 09:45 PM   #15
CHEROKEEMUDMAN01
mellow yellow
well got the exhaust done on tuesday. they were able to run true duels so it should sound healthy cant wait. here is a few pics
Old May 5th, 2011, 10:25 PM   #16
dukeneutron
dukeneutron's Avatar
gotta 318 in the garage screaming to go in the tj. should be a blast to drive.
dukeneutron is offline   Reply With Quote
Old May 5th, 2011, 10:29 PM   #17
CHEROKEEMUDMAN01
mellow yellow
cant wait to be able to drive it, this is the longest i have had any project not running and its killing me.
Old May 6th, 2011, 08:21 AM   #18
curbdog17
Mini Van
curbdog17's Avatar
Looks great dude, I bet that its going to scream.
Old May 6th, 2011, 04:40 PM   #19
CHEROKEEMUDMAN01
mellow yellow
thanks guys. i think with the little head polishing we did and the good cam and 2500 stall on that build trans it should be a fun toy. hopefully the jeep holds up though under the hp. i am going to stiffin the unibody up with this kit (http://www.hdoffroadengineering.com/collections/frontpage/products/xj-frame-stiffener-set) so hopefully it will hold up well.
Old May 15th, 2011, 07:41 PM   #20
CHEROKEEMUDMAN01
mellow yellow
well got married on saturday and spent to day cleaning up after the party. i got the jeep back to its home so hopefully in next couple days i can get to work on it and have some more progress pics
Page generated in 1.93326 seconds with 83 queries
