Gear ratio for 37"s ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2011, 09:07 PM   #1
Nvrenuf
Nvrenuf's Avatar
Default Gear ratio for 37"s ?
Trying to decide which gears to use. I have a YJ on 37"s with the 4.0, AX15, 231. Most charts point to the 4.88 - 5.13.
Is that deep enough? How about when I move to a 400 SBC with 700/231?
Old March 5th, 2011, 09:09 PM   #2
schanxj
schanxj's Avatar
What axles are you running?
schanxj is offline   Reply With Quote
Old March 5th, 2011, 09:10 PM   #3
ssdeuces
ssdeuces's Avatar
? X2...you just asked the same question I'm looking for the answer to.
ssdeuces is offline   Reply With Quote
Old March 5th, 2011, 09:11 PM   #4
MiNi Beast
MiNi Beast's Avatar
I'll be running 4.0 set up with 5.13's and running 37's good gear set up.
Old March 5th, 2011, 09:12 PM   #5
Nvrenuf
Nvrenuf's Avatar
Front HP60 and rear FF60 thinking of boring the spindles for 35 spline or moving to 14bolt.
Old March 5th, 2011, 09:13 PM   #6
MiNi Beast
MiNi Beast's Avatar
move to 14 bolt now if going to re do gears anyways, come out better in every way.
Old March 5th, 2011, 09:14 PM   #7
Marine_mike
SNSHTF
Marine_mike's Avatar
I was running 4.88s in my waggy 44s on my 91 YJ with a 4.0/tf999/231 with 36" TSLs. They were good to go. i prob had some wiggle room to run 37s on that gearing too.
Click this link ---> http://www.gunwatcher.com/c/5751 is having a HUGE giveaway at the end of December 2014!
Marine_mike is offline   Reply With Quote
Old March 5th, 2011, 09:20 PM   #8
Nvrenuf
Nvrenuf's Avatar
That's what I'm leaning toward but like the 60 clearance, not looking to buy bigger tires.
Old March 5th, 2011, 09:22 PM   #9
schanxj
schanxj's Avatar
I just went through this decision process! Was looking at the dana 60 rear, dana 70, corp 14 bolt and the old HO72. The 14 is the clear cut winner. With a setup like that you may want to look at 5.13's or 5.38's.
Old March 5th, 2011, 09:24 PM   #10
schanxj
schanxj's Avatar
This should help you out.
http://www.grimmjeeper.com/gears.html
as well as:
http://www.4x4offroads.com/gear-ratio-chart.html
Old March 5th, 2011, 09:36 PM   #11
ssdeuces
ssdeuces's Avatar
thanks...I needed that! a beer or two for all of you....
Old March 5th, 2011, 09:53 PM   #12
Yeah, either ought to be ok for both setup. I've got a pair of axles with 5.13s which will be going into my scrambler, with 36s. I believe I ran the numbers to be about 2200 rpm or so in 4th gear @ 60mph for a 700R4. I'm going with a a TH350, though.
Old March 6th, 2011, 11:37 AM   #13
Cool parts peddler
Ironman Offroad's Avatar
5.13 for the win!!!!!
Any higher numerical gear, and the pinion gets too small.
Wish I had them instad of my 4.88's.
Old March 6th, 2011, 12:39 PM   #14
TimberwolfFXDL
Short Guy, Tall Jeep
TimberwolfFXDL's Avatar
Bought 5.13s for my 37s... but I'm in a JK
TimberwolfFXDL is offline   Reply With Quote
Old March 6th, 2011, 12:50 PM   #15
Silver93XJ
Silver93XJ's Avatar
runnin 5.13 with 36's and love it!
Silver93XJ is offline   Reply With Quote
Old March 6th, 2011, 12:56 PM   #16
Nope, he should stay with the 4.88's. He's only running 37's which are not quite 37" while you are running bigger. He's also planning on swapping in a SBC. 4.88's will be more than low enough............ ask me how I know.
Steve,
I'm currently running 4.88's. I never really have wanted for more power but I'm running a fair amount of HP. If you are truly planning on going to a SBC, I would go 4.88 even if you feel a little under powered now. On the other hand, if you are going to wait a long time, I would agree with Dale.
Old March 6th, 2011, 07:30 PM   #17
TommyCJ7
TommyCJ7's Avatar
Great info guys - thanks also. I will be doing gears in a few months and was trying to decide between 4:88 & 5:13 also. 5:13's it is as there is no SBC in my future, just my little 4.0
TommyCJ7 is offline   Reply With Quote
Old March 6th, 2011, 07:47 PM   #18
Tom, are you staying with the NP231?
Old March 7th, 2011, 11:21 AM   #19
TommyCJ7
TommyCJ7's Avatar
Jim - currently i'm running the stock 242 and so far so good. Not planning on changing unless I have problems. I am looking at gears when the D60 goes in the front in a few months. Finishing the roll cage first, then gears.
Old March 7th, 2011, 03:23 PM   #20
curbdog17
Mini Van
curbdog17's Avatar
Im running 5.38's with 36's and I like the way it runs.
4.0
Page generated in 1.59708 seconds with 83 queries
