Suggestions, crank no start Delete, solved - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2011, 12:18 AM   #1
crash n burn
For sale!
crash n burn's Avatar
Default Suggestions, crank no start Delete, solved
'94 5.9l with nv3550 trans. engine cranks but wont start. changed the crank sensor and the coil with no luck. any suggestions?
crash n burn is offline   Reply With Quote
Old March 4th, 2011, 04:26 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
auto shut down relay kicked in, that or the fuel solenoid is dead?
if its the relay un hook the battery and kill all power for minimum 15 minutes. then hook up and try again.
Yetti
Old March 4th, 2011, 05:41 AM   #3
JeepInABox
In too deep
JeepInABox's Avatar
are you lacking fuel or spark?
Do you get a 3 second fuel pump prime when you turn on the ignition?
will the fuel pump turn on if you bypass the fuel pump relay?
Old March 5th, 2011, 03:46 AM   #4
crash n burn
For sale!
spark for sure.
will check the prime on the fuel pump and bypass
yetti later today i'll try the battery
thanks guys
Old March 5th, 2011, 07:08 AM   #5
Yetti
Yetti's Avatar
Originally Posted by crash n burn View Post
'94 5.9l
Is this a gasser? or diesel? as I was giving info for a diesel.
if its a gas then by all means clear the auto shut down relay by un hooking the battery. if your still struggling to get fire, the fuel rail has a schrader valve you can hook a gauge to. it should be making about 45-49 psi if you cycle the key to crank. if you have that and spark it should run.
Yetti
Old March 5th, 2011, 03:08 PM   #6
dodgeboy
redneck truck club
dodgeboy's Avatar
spark for sure.
thanks guys
im gonna guess gasser.... he said it has spark. if it has fuel pressure and spark it doesnt always mean it will run. there is still a pick up coil but your heading in the right direction.
dodgeboy is offline   Reply With Quote
Old March 7th, 2011, 07:54 AM   #7
crash n burn
For sale!
it is a gasser. tried pulling the batt with no success. in the next few days i'll have to borrow a fuel psi tester. and try the bypass
Old March 9th, 2011, 12:43 PM   #8
Flat_Black
The Dodge Guy
Flat_Black's Avatar
bingo.
also check the fuel pump relay/ auto shut down relay, its 2 relays in on one bracket. on the magnum motors its only a few things that ever go. asd/fuel pump relay unit, cranck sensor,pick-up coil, and the fuel pumps do tend to shit out.
Old March 19th, 2011, 06:42 PM   #9
crash n burn
For sale!
ok..... replaced cap and rotor. i jumped the fuel pump, it works. i pulled the batt for 8 hours. i swapped out the fuel pump relay and auto shut down. nothing! still wont fire.
could it be the igition module? how could i test it first?
fuel pump - worked when jumped
cap and rotor - new, replaced
coil - new, replaced
fuel pump relay - swapped
auto shut down - battery pulled, relay swapped
Old March 19th, 2011, 11:09 PM   #10
JeepInABox
In too deep
JeepInABox's Avatar
Old March 19th, 2011, 11:31 PM   #11
crash n burn
For sale!
That's the problem I can't hear it when I'm in the heep. But I can hear it when I jumped the relay. I haven't had a second person to listen while I crank it. For argument sake let's say its not getting the 3 second prime when I crank it. What should I check?
Thanks
Old March 19th, 2011, 11:38 PM   #12
JeepInABox
In too deep
JeepInABox's Avatar
ignition on prime, not crank
Old March 20th, 2011, 01:29 AM   #13
crash n burn
For sale!
Ok. Thanks. Will try in the next few days
Old March 20th, 2011, 09:30 AM   #14
Yetti
Yetti's Avatar
How does that work? I thought the pump only ran prime while cranking?
Yetti
Old March 21st, 2011, 06:37 AM   #15
JeepInABox
In too deep
JeepInABox's Avatar
There is a fuel prime where at ignition on, then it turns off until the signal from the cranck sensor is seen.
This will check to see if the asd circuit is ok, if the fuel pump primes.
Then we can either go after the cranck sensor circuit or the asd wiring.
Old March 21st, 2011, 07:33 AM   #16
Flat_Black
The Dodge Guy
Flat_Black's Avatar
im thinking pick up coil if all that has been checked and workin. under cap and rotor in the dist, held in with 2 phillips head screws on the out side of the dist.
Old March 26th, 2011, 06:36 AM   #17
larryl
just a jeep
larryl's Avatar
i got a 98 ram 1500 did the same thing
had a shop look at it
no 3sec prime it was the Computer
they ran a jumper wire for fuel pump to run when key on
larryl is offline   Reply With Quote
Old April 8th, 2011, 12:18 AM   #18
crash n burn
For sale!
i hope its not the computer!
fuel pump does not prime or run when cranked. fuel pressure is 0 psi
when jumped at relay i get 40 psi, when cranked it still doesnt fire.
will check the pick up coil next
Old April 8th, 2011, 05:55 AM   #19
JeepInABox
In too deep
JeepInABox's Avatar
you need to check the ignition switch circuits and the powers and grounds on the pcm
Old April 9th, 2011, 05:37 PM   #20
crash n burn
For sale!
thanks, cause its not the pick up.
silly question but where would the circuits be? if the weather holds tomorrow i'll start checking grounds and power.
thanks again
Page generated in 0.37014 seconds with 83 queries
