01 2500 Ram, Heater core issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 1st, 2011, 06:51 AM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Default 01 2500 Ram, Heater core issues
I think my heater core may be shot. How can I prove this before pulling the dash?
Currently I have found several puddles and drip lines under and on the passenger side exterior firewall.
When I turn the heat on it smells horrible, a nasty residue forms on the window and a smoke rolls out of the dash vents.
Because of the residue I'm not sure if the heat warms up.
I also understand this is a pain in the ass job on a normal truck but add in the fact that my truck is lifted 11" how difficult will that make it? Any tips to make this easier?
How much would this cost at a shop to have fixed?
Silver Bullet is offline   Reply With Quote
Old March 2nd, 2011, 07:34 AM   #2
Silver Bullet
I'm surprised no comments. Dodge's re very common and I thought this was a fairly common issue.
Old March 2nd, 2011, 07:49 AM   #3
kevinr839
kevinr839's Avatar
Could it be a plugged drain tube on your heater box? That would allow funky water to build up in there. Does that truck have a cabin air filter? If it does that should be changed also because it can seriously block airflow in there. Are you losing antifreeze?
kevinr839 is offline   Reply With Quote
Old March 2nd, 2011, 05:27 PM   #4
Silver Bullet
Nothing noticeable.
Old March 3rd, 2011, 07:45 AM   #5
7.3X
Fullsize support vehicle
7.3X's Avatar
We just did a heater core on a 2001 Dodge Ram 1500, and yes it is a pain.
You will need to drop the steering column down and pull the air bag.
Then if that is not bad enough you need to pull the entire dash loose from the firewall and pull it. The heater core stands straight up with the inlet and outlet tubes having several bends that make it difficult to pull out I cut them off. The new one is no joy to put in as the box wants to be removed due to the bends in the tubes and lack of room to wiggle. just be patient it will take time and several different size of sockets and a t-25 torx bit.
Good luck.
7.3X is offline   Reply With Quote
Old October 3rd, 2011, 05:42 PM   #6
rammanriley
rammanriley's Avatar
Im sure you already did the job but when I did both cores on my 96 (EVAP and Heater) I was able to drop the column and un bolt the dash. Then put the pass side up on the passenger seat and sneak the whole case out. make sure you pay attn to where all the doors go etc. took me about 6 hours start to finish. Also make sure to get the A/c system recovered.
rammanriley is offline   Reply With Quote
Page generated in 0.51174 seconds with 41 queries
