Hydraulic steering - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2011, 09:45 PM   #1
onebadmudder76
onebadmudder76's Avatar
Default Hydraulic steering
Anyone out there got any tips or ideas for hydralic steering?? Ive got an orbital valve mounted to my steering column already just wonderin if I can use stock steering pump off of 78 ford er what
onebadmudder76 is offline   Reply With Quote
Old February 28th, 2011, 07:48 AM   #2
kwiers
kwiers's Avatar
i used a stock pump with mine and have hydraboost brakes also. just make sure you have a resivor with some volume and a cooler and you should be fine
kwiers is offline   Reply With Quote
Old February 28th, 2011, 07:50 AM   #3
onebadmudder76
alright thanks what did you use for a resevoir?
Old February 28th, 2011, 08:18 AM   #4
kwiers
kwiers's Avatar
i made a container out of some aluminum tube. capped the ends with a filler on the top, return in the side close to the top. then out of the bottom no less than a an10 or 3/4 size hose connected and sealed to the top of the factory pump. blocked off factory return on pump. mine is ran in this order and 2 years of trouble free use, pump-hydroboost-steering orb-return to cooler (tranny cooler or equivalent) then ressevor
Old February 28th, 2011, 08:28 AM   #5
kwiers
kwiers's Avatar
almost for got, make sure you vent resivoir filler cap. and mount the resivoir higher than everything in the system.
Old February 28th, 2011, 10:44 PM   #6
roger
roger's Avatar
Send a message via AIM to roger Send a message via Yahoo to roger
i use the stock resevoir and put a 1 1/2 rubber tube to 1 1/2 steel nipple and screwed on a
p.s i used 2 hose clamps
roger is offline   Reply With Quote
Page generated in 0.18282 seconds with 41 queries
